Touched bottom - What could it be?
Well-known member
Ok, on our first run on the south shore we touch bottom at idle speed and had to wiggle off the sand.
Since then I think I have a vibration just above 1000RPM till the engines spool up (1400-1500rpm) and the port engine is running at 5-7% higher load & 1-4 higher GPH as the starboard engine at synced RPM. This is per the CAT EEC readouts that have been very accurate
The boat runs very strong and smooth at cruise RPM's & Load (1900-2100RPM & 70-85% load) with no problem getting to WOT/100%load and all is smooth running.
My CAT Tech/surveyor is going to take a dive and check out the running gear on Tuesday or Wednesday to see if I screwed up something
Any guesses of what's up?
Sorry Andy, it is likly a bent blade. Back to propscan.
Tiffany Jewelers Inc. is the sole authorized supplier of props to Cruisers owners:
Yea, probably just tweeked one of your blades just a little. Big blade = big scoop of sand....
Sounds like you bent a prop.
i would suggest sending a local diver down to investigate.
Costly nav error. Where is the shallow water alarm set on the sounder? Perhaps a deeper setting would be advantageous? Even at idle speed a fifty footer is covering ground quickly and reaction time is pretty limited.
Hope it works out quickly for you.
Originally posted by Butch Davis
Costly nav error. Where is the shallow water alarm set on the sounder? Perhaps a deeper setting would be advantageous? ......
I was following someone with local knowledge and did not follow my charts
My Bad, I should always follow my charts and gut feeling [:-banghead][:-censored]
When I get in a shallow area I frequently shift to neutral and drift over the spot. I have also found that lifting my feet up helps too.
i wondered about your boat in the south bay I had a 4' draft, keel boat, that frequently found bottom but with no expense. I dont think I would take my present 4.5' draft boat into the south bay.
Bruce,
I only have a 42" draft with a keel
and lifting my feet & A$$ did not help
Besides "polishing" the blades, "wiggling off the sand" can put a load of abrasive in your cutlesses and let your intakes for anything that is running vacuum up a lot of sand as well, plus put an unnatural load on the struts in bad directions. Sometimes it's better to try to kedge off with power shut down if conditions allow. Granted , that's not our instinctive response.
Originally posted by Silverton_34
So did anything happen to the boat you were following?
I was going behin two other boats and both are fine - I'm the lucky one
Didn't hold you breath, curse, pray, jump, send everyone to the bow did you? The shallower draft boats being followed did not kick up sand? Tough luck on that one. Everyone eventually gets a turn.
Update
I had the boat hauled and sent the props to the Builder – Both props out of balance and the port had a bent blade – they are amazed that the boat ran as well as it did
I guess the good news is that they well be adding more cup to the wheels for a little more kick
Did the shafts turn without gritty-grinding at the cutless?
Sandy - they appear to be ok – the yard is checking them today
My boat has prop tunnels as well as a small keel, it looks like I pivoted on the tail of the keel and the wheels without getting the struts into the sand – I am also looking at the rudders as well
mAKE SURE HE CHECKS YOUR RUDDERS WHILE HE'S DOWN ALSO.
I told u this sand box surb2rb2@gr5tgr5t#'s
How can one set a depth finder when ur in NO water to begin with ???
Id make whom ever u were following pay!!!
I do notice that dave and walter are awfully quite !!!!!!!
Never follow a guy with outdrives from the south shore. They don't care where the channels are. :-)
I wonder what the response would be if this was Bob who Posted this?
