towing a pwc???
engdockter
I was considering buying a pwc[large one 1200 3 seater yamaha]instead of a dingy,we have a 10 meter trojan sedan bridge,has anybody had experiance towing one and could you tell me how did it do. thanks for your input.
Towing anything can be a major hassle and lead to some big problems. The two primary concerns are swamping/capsizing the tow and having the tow rope foul the props on the big boat.
When you tow behing your cruiser you will find that there are several "swells" behind you. The peaks and valleys of these swells, both size and position, change with speed. It is important that you watch your tow carefully to make sure that it is in a favorable spot in the swell. You don't want to be constantly pulling it up the backside of a swell, as that will put a lot of strain on the tow line. On the other hand, you don't want the tow to be surfing down the face of a swell either as that can lead to slack in the rope, which will end up jerking, possibly breaking the rope or capsizing the tow.
Eventually you get to a the anchorage, slip, gas dock, etc. A sudden slowing of the cruiser can end up with the tow rear-ending you. Stopping, or even worse going into reverse will have the tow rope go slack and possibly get into your props. The very nature of why you were stopped means that this will happen at a very bad time in a very bad spot.
If you have an extra crew member it will often be best to get them off on the PWC before leaving the dock, then have them join you once you are in open water and start the tow there. Do the reverse on the way in. You may want to consider using a line that floats, but be wary of the poly ropes as they deteriorate fairly quickly and you certainly don't want to lose your tow!
For towing a PWC I would recommend that it has an electric bilge pump installed. Most of the PWCs have a siphon pump that will keep the bilge dry when the engine is running. When you tow, however, any water that works its way into the bilge will just stay there.
Rod
You also need to install a valve, or clamp the cooling water feed line. While towing, water pressure forces water thru the cooling system, and without the engine exhaust pressure blowing it out the manifold, water can build up and enter the cylinders. Thats how it is on my honda that I tow. New seadoos have heat exchangers from what I hear, so it might not be an issue with these.
Any two stroke needs the cooling line clamped to prevent possible engine damage, the four stroke water cooled engines are ok as long as it has the cooling plate. It is a pain in the backside to tow them around. I have seen rooler clamps that are on the swwim platforms and they are stored on them.
That's a pretty heavy craft to be towing all the time. Much different than towing a dingy.
