Towing a Tank
Pilotpak
No...Not that kind of a tank ! !
I'm building a house on a block of land that doesn't have any road access (yep..stupid..I know), only has river access.
The first part of the build involves getting two 5,000 gallon rainwater tanks to site, but the local barge operator has a $2,200 minimum charge. So, I'm thinking about towing them to the site with my 31' Larson.
Tanks are made from Poly, about 12' wide by 6' high, weigh 850 lbs each. Waterway is smooth, very little traffic or current, distance is 2.5 nautical miles.
  • Anyone done anything like this before ?
  • What breaking strain tow line should I use ?
  • Should the tow line be the Floating or Sinking kind (in case of a break) ?
  • I'm going to add a retrieval line with a float, just in case of capsize. Any idea what size retrieval line I should use ?
Wayne
Larson 310 Cabrio
Go for it. IMO you're worrying too much; the towing is the easy part. I'd commandeer the spare anchor rode; you won't be using a lot of power so it will be more than strong enough. The hard part will be getting them out of the water once you get there.
First things first, what kinda power do you have on your Larson?
as for your tow line, I would suggest a line that can handle 3 - 4 x times the weight of your payload. You never know what might happen, high winds, strong current. Just for reference, we have a 5000+ 4wd and when we go off roading our recovery strap is rated for 30,000lbs. Now I went a little bit over board with the 30K strap but you can never be too safe.
I would think a sinking line would create more drag, I would opt for a floating line. just be sure no one is standing anywhere near the transom when your in tow.
hope this helps
I'm with Willie, as soon as I read through your project the main thing that sounded tough to me was getting the tanks in and out of the water. Just take your time since those tanks definitely won't react well if pulled over a couple of mph.
If the weather were nice and I had a project like that, I'd probably use a jetski. Not that it was wise but I towed my 34' houseboat 6-8 miles by myself with an 80hp 16'fish n ski. Getting it out of the first marina, under a bridge, and docked at my dock were the only hard parts.
A capsize of the tank, or your boat??? If it's the tank what happens if it capsizes?
Those tanks are gonna wander all around and put a trememdous strain on your tow rope and whatever you attach it to on the boat. You will have no control over them. I assume they have a flat front which is gonna be plowing a LOT of water out of the way.
Make sure the cleats are through bolted with adequate backing plates.
We had a cabin on an island in NW Wisconsin (Bear Lake) when I was a kid, and Dad towed a 1000 gallon steel spetic tank to it with just our little Martin outboard and 14ft aluminum boat, so apparently it can be done... what a sight though...
Would a Sea Anchor towed behind the tank help to keep it from wandering??? I know it will add some xtra drag but may help.
Perhaps place them on a raft or other platform? Strap them down and tow them away! Or do one at a time.....?
I am with Joe on a small sea anchor or even better to have another boat hooked up in trail that could keep the tank straight.
Your problem isn't power, it's maneuverability.
Iman is right; a jetski or a dink could very likely do a better job than the 31' Larson.
I've towed a 28' Pacemaker with a 10' skiff and a 4 hp motor. Rather than use a towline though I put it "on the hip". Used 3/8" line, had NO problems whatsoever. Pushing or hipping is usually much easier than a towline. (admittedly I picked my weather).
I have SEVERAL times towed my 35', 9 ton houseboat with a 17', 90hp fishing boat. Again, I put it on the hip(with lots of fenders); used maybe 1/4 throttle. No Problemo.
Agreed, secure the tank alongside and proceed slowly .. pick the right weather day and go for it ... should not be a problem if you are careful.
I helped a buddy tow a 4000 Gal tank from Juneau out across the straight to an island.
We just sealed it up and dragged it behind a 21'....it was about a 15 mile trip as I remember across open water.
We didnt have any trouble until we got the the beach, which was rocks.
I think we used Halibut Ground line for lashing and towing.
Dont worry about losing it Pete.
It'l float. Just tie it on a ways behind you so it's wallowing and rolling wont bother the tow line or the tow vehicle.
Go slow. Idle or better and enjoy the ride.
Hells bells, as long as you don't have a lot of wind. We move 15000+ lb duck blinds to and from their anchor with 14-16' duck boats and 10-25 hp.
I have seen old pontoon boats stripped of seating, consoles, and engines used as barges for hauling building supplies.
I've caught many shark over 400 pounds on 30 # monofliment... I don't see a problem here using standard 1/2" line. I'm sure those sharks fought better than 800 #'s of dead weight at times. As far as friction of line that sinks... neglible... They will follow your boat just fine and not wander... just like a big old oversized dingy...
Was trying to keep out of this one, keep my mouth shut, you all know I don't like to make waves and I'm kinda shy...okay, that's bullcrap, I just didn't want to be the alarmist until we started talking about towing alongside and towing with jets...STOP!!!
STOP STOP STOP STOP STOP STOP STOP!!!!!
Even with boats, things that are designed by people waaaaaay smarter than me to move through the water with minimal resistance, you DO NOT tow them alongside until you're in protected waters, in the last spot before your final destination that you have space (once you get good, it doesn't take much space. For example, I'd do it in a bathtub - without going past clutch speed ;) ) to break it into alongside gear. Now, a tank that you say does have some possibility of capsizing? You tell me how smart that would be to make it up alongside. Bad, bad, BAD idea. I'm talking peeing in the toaster kind of bad idea. Diving deep with my spare regulator that I bought cheap on E-Bay so I could take it apart and see how it works kind of bad idea. Drinking with ugly chicks kind of bad idea. Get my drift here? Think about this one for a minute.
Secondly, like someone mentioned, these things aren't designed to efficiently displace and replace water. You'll have to go reeeeaaal slow. Any head current and you're making sternway just to keep your tow and rig from parting and severing your head from your shoulders (parting towlines aren't your friend. They'll hurt you. Kneeling at your coffin saying "all for a water tank" kind of hurt. Put simply, let's consider 2" circumference double braid, which is just slightly, barely larger than 1/2" diameter, has a breaking strength of roughly 25,000 pounds. So when it parts - and you'd be stunned at the net forces in a tow rig, you could easily part 1/2" diameter nylon line with the tow you're describing, without even getting heavy on the sticks - it releases 25,000 pounds of energy, force, bad karma, big hurt, whatever you want to call it - and it releases it in the nearly precise direction of the back of your head. Cool or not cool?
C. - Your insurance won't cover damage to your boat, damage to anything else, recovery of the tank, or recovery of the head the parted towline sent drifting gently down the stream (merrily, merrily, merrily, what a rb2@gr5t#$ty dream...)
Sixth - Jet drives suck for towing astern. I mean, they're terrible. Towed quite a bit with single and double jets. Hated it. Not so bad in an alongside rig, but see para(6)A.2b(7.4k) above.
And B - I haven't thought of B. I'm winded. Give me a minute here.
Oh yeah. Floating towline is bad. You want catenary (this is the 'dip' in the towline caused by it's own wet weight - it's your shock absorber. Even more important than voting Republican) in the water. Catenary is very very important. It's (part of) what keeps you from parting the towline and all the very bad things that would ensue.
12' wide by 6' high isn't going to capsize unless it's round....so what shape?
850 lbs ain't much spread out over a large area so it's probably not going to sit lower than an inch or two. How much drag do you think will be involved anyway. If you can strap both side by side, there's no way they can capsize, either.
I don't see any problem towing at a few knts. Hardest part is moving into and out of water and over land.
i think at best you have a major goat rodeo and at worst what November Charlie predicted happens.
edit. for my money I would listen to someone with the experience of NC
