Towing and outboards
WaxedElvis
I read somewhere a while back, I can't remember where, an outboard should be left in gear while being towed (on a trailer) so the prop doesn't windmill in due to airflow. Has anyone else heard of this? I followed a twin outboard boat down the interstate yesterday and both props where spinning.
NO!. If you're towing in the water you might put it in gear but it really doesn't matter. Towing down the road, the props won't spin fast enough to create any heat and the entire gear assembly is submerged in oil. Towing in the water the prop will spin faster, of course, but the gear case being submerged is totally water cooled and still full of oil protecting all the gears and bearings.
So, basically, leave it out of gear.
JMNSHO &, of course, YMMV
On the older Mercury's(pre tilt and trim and some of the newer small motors) they had a tilt lock on them so that the motor wouldn't tilt up on you when you put it in reverse. The motor would unlock when in forward so that if you hit anything it would tilt up. It was recommended to tow with the motor in gear for this reason. But like gainso said it doesn't have anything to do with the props spinning.
