Trailer Coupler Releasing Problems
justgotaboat
It seems that sometimes when I go to unhitch my trailer from my truck the coupler does not actually release correctly and stays attached to the ball. Everything is released correctly, however the coupler will not always release the ball right away. I typically leave my trailer hooked up for the duration of a trip until the boat is backed into the driveway where it lives for the most of the year. I have tried chocking the wheels and putting a slight amount of foward pull after backing it in thinking the reverse motion is jamming it somehow (the trailer does have an electric brake release so the brakes dissengage when backing up). I have also tried leaving the truck in nuetral (with someone at the wheel of course) thinking that any directional force could cause a hold up. In desparation and annoyance I even occasionally give a decent jump on the rear bumper or use the trailer jack to jack the rear end up the truck up a good 6" above where the release should be. Sometimes it works and relases with the extra force, but sometimes not. When the trailer is not hitched up, everything functions normally, you pull up the tab to release the ball and the coupler slides back and out of the way. It is a new venture trailer with the correct size ball.
Any suggestions or thoughts? is this a common problem? I feel like when released the trailer should just slide right off the ball once the trucks springs reach their normal ride height, right? Should anything get an extra layer of grease to help things slide better?
I have a steel tandem trailer that weighs about 1500 lbs that does the same thing. What works for me (most of the time, boat on or off) is to jack the tongue up until the truck bumper stops rising, then give it a few more turns. Then, with trailer wheels chocked, a quick, short jerk forward or backward with the truck usually frees it.
Have you tried some grease on the ball and the inner workings of the coupler?
May even have to loosen the nut that holds the coupler slider a half turn or so. Be carefull not to loosen to much.
The old timers will tell you to pour 30 weight oil into the coupler mechanism. This makes a big mess, but will sucessfully oiling the whole mechanism.
Don't get pissed at me but do you have the correct ball for that coupler they both should be marked. Don't assume check them both.
So after you unlock the coupler you have already chocked the wheels of the trailer and then, give a little tug forward and a little tug backwards with the tow car or truck it doesn't pop down the tounge that holds the ball from underneath?
just checked your in Jersey? I'm in Manalapan email me chiefalen"at"aol.com i'll look at it for you for free and i have a good cheap trailer co. near me they won't screw you if you need it fixed. That is if i can't fix it.
Justgotaboat,
I've got a 29 Ft. cruiser on a trailer and have the same problem unhooking,sometimes. I have to do the bump forward and back to get it to release.
The thing I would caution you about is, be double sure that the hitch goes DOWN on the ball when hooking up. Don't ask how I know1:)
If you have surge brakes (I take from the OP that you do) after you back in, the coupler is probably compressed, even though the brakes are electrically released. Just get some up pressure on the hitch by raising the jack, then move your vehicle slightly forward. This should release the ball.
Had the exact same issue on my 32' MagicTilt. I ended up removing the coupler from the trailer, disassembling it completely and loading up the entire mechanism with Mercruiser Anti Corrosion grease. Any grease with anti corrosion additives will work, and the heavier the better.
That solved it for me and it has been 18 months now with no recurrence.
chock the wheels and then put the truck in neutral or maybe some forward if the master cylinder is still compressed. then start raising the jack.
i also keep a really big flathead screw driver in the back of my truck. if you bend over into an incredibly uncomfortable position to look at the coupling mechanism i can see if the coupler is open enough or if it needs to be pry-ed a little more. again, move the truck and mess with the coupler BEFORE raising the jack. raising it too early puts tension on the ball.
I do infact have the correct ball and hitch. both are marked on them 2 5/16". I triple checked that one. The trailer always slides right down onto the hitch, never any problems with that. I do have surge brakes and have tried to chock the wheels and give it a tug forward to releive the master cylinder before releasing or jacking up the trailer, but it still seems to get stuck sometimes. Sounds like a nice heavy coat of grease to lube her up will help, and hopefully that will help out
thanks all
Unless where you park is perfectly level this is usually an issue because of bind. I had an uphill grade where I parked and always had to struggle getting the ball to release. My methods were to block the trailer wheels and run the trailer jack down until the truck started to raise then I would jump up and down on the bumper while the admiral moved the truck back and forth slightly but... I had a couple of times when I had to pull the pin on the receiver and drive the truck away.
Good luck
Niles
What orboater said...........check the tightness of the nut holding the ball clamp mechanism inside the coupling. I had your problem once, years ago and the mechanism was too tight. When released there still wasn't room for the hitch to come off the ball. ½ or ¾ of a turn on the nut may just do it for you. As he said, be sure you don't get it Too loose.
Lar.
I chock the trailer wheels, jack up the trailer till it appears to be lifting the truck, get in the truck and put it in neutral and let it settle out. usually works.
We trailored a 18' Celebrity I/O on a dual axle custom trailer and experienced your described problem. What worked for us was a couple shots of WD 40 to soak the coupler mechanism with lubricant befor we hooked up. After lubriacating I would activate the release lever several times.
My driveway that we park in is perfectly flat. So if it is a bind problem, it is due to backing the trailer in. But as I have said before, I usually try to remove any bind by either putting the truck in neutral, or in drive and putting some tension in forward to unload the coupler. It seems like the amount of jockying forward and neutral and reverse and jumping on the bumper just is not right. I will look into a slight turn on the nut holding the coupler in. And a lot of extra grease and lubricants all over everything.
Sounds to me you need too grease the coupler as well or first Wd40 THE CRAP OUT OF IT. If you never WD40 the coupler or greased it. you may want to just replace it and maintain the new one. I had the same problem, and never maintaied it, replacing and then maintaining solved this.
Not sure, but if you remove the coupler and pull it apart and clean it well, you may not need to replace it. It was pretty cheap for me to replace the coupler, easy to do, that is why I went that route.
the trailer is a new 2009 venture trailer. i would agree maintaining is better than replacing, but being less than a year old trailer I should be able to grease it up and not worry about replacing as of yet
