trailer tire psi
rinker 192
Looking for some help with trailer tires, my buddy has a Stingray 19 ft. and he has blown 3-4 tires the last couple of years! We run the same tires came fac. on my trailer Carlisle (ST215/75/r14) max. psi cold 50 psi. I've run mine at 50 never an issue he's tried 40 45 50 keeps having problems? Does anyone else have this and does everyone run max cold psi
thnx. for any info
doug
What brand of tire? I bet they're Carlisle tires...
Oops, didn't read the whole thing. Carlisle tires are known for this problem. They should be replaced.
Yes they are acually are Carlise and one Good Year! I've run carlisle on my 05 no problems knock on wood! Does everyone else run at max cold psi? Bob, how do you like your Larson I'm looking a new 06 lxi228 280hp bow rider!
thnx. for the reply
Check the sidewalls for the max cold psi pressure...small print, but there somewhere. Usually 50lbs psi cold. Get Goodyear Marathons...dump the Carlisles.
I have a tandem trailer with Carlisle tires. The boat was towed 1000 miles from Maine to Michigan when we moved last December. 4000 lb boat, full gear and gas tank, and then we started throwing stuff in the cuddy and cockpit as we ran out of space in the moving truck, no problems whatsoever. Lot of weight on those tires and they did 500 miles two days in a row. Tire trailers seem to be hit or miss as I've seen people trash talk Marathons like everyone seems to be doing to Carlisles here.
WOW! Your Carlisle tires lasted 1000 miles? That's pretty good! I've had Goodyear tires for years, probably lasted more than 20,000 miles.
Trailer tires, interesting beasts. ST tires (special trailer?) are rated for a max of 65 mph. How many times have you seen guys towing much faster. Also, I see a lot of overloaded trailers and under inflated tires. No wonder so many people have problems. The max inflation pressure indicated on the sidewall is what you need for the max load rating of the tire. Going over any of the limits is just asking for trouble.
FWIW and as an example, I have a dual axle (6000 axles) with 3k rated tires 65psi cold (carlisle radials, ST245/75R16). My fully loaded boat and trailer weigh in at 11,000 (cat scales). With a tounge weight of 950 lbs, call it 1000, I have about 10,000 lbs sitting on the axles. Tow it all with a 1 ton diesel pickup at 60-62 mph highway. Everything is within spec, no problems to date. Will probably replace the trailer tires regardless of mileage at 4 or 5 years due to possible UV degradation. If I loose one tire going down the road, the 9k capacity of the others should get me to the shoulder and to a safe spot to put on the spare as long as I slow down immediatly.
You probably know this, but for others, if you blow a tire, don't slow down immediately. Hard braking can abruptly change the weighting across the tires and can then cause loss of control. Slow down gently and in a straight line.
goplay, glad you brought that up. Just ease off the "go" pedal to slow down gradually and possibly brake lightly. You are exactly correct - don't jam on the brakes in this situation.
20,000 on a trailer tire? Very few people do that much towing as that is like crossing the country 6-7 times. No offense, but I doubt the accuracy of your statement.
Underinflation will blow your tires, whether car or trailer. When your tires are underinflated they flex constantly and become very hot as a result. Also on turns they roll a lot more and stress the sidewall materials. When you think about a tire with a recommended cold inflation of fifty pounds, and you inflate to forty pounds, that's better than ten percent below recommended pressure. Then you throw a boat on top, drag it behind the towing vehicle so it has awful sideloads - you are flexing that tire something fierce. On a trailer go to the tire's stated cold inflation, on a car go to the door sticker - not the tire - inflation.
