Gavin_Eville
- Mar 30, 2007
- 25694
- 14
So after about 8 hours of trouble shooting a running light issue, I have come to the conclusion that the many trailer running lights are drawing too many amps for the trailer wire harness to handle. My plan is to run a relay from the battery back to the running lights to power them. See setup below and let me know if anyone thinks that this is the case?? By the detail you can see I have been at this for a while!!
2001 Izusu Rodeo with electric brake controller, and standard 7 pin wire harness into the stock rear wiring (reverse light spliced in as well). The trailer is for a 2004 19' Glastron, with 13 running lights, reverse lights, brake/turn lights and electric brakes. I just wired the Rodeo for the first time, everything works great (brakes, brake lights, turns, reverse lights) until the running lights are switched on via the headlight switch. Then they are so dim that you can barely see them, and the reverse lights on the trailer and Rodeo light up a tiny bit. I get full voltage on the Rodeo running lights at the truck end of the 7 pin plug, until it is plugged into the trailer, then it drops to almost nohing. Everything is grounded properly, all the running lights on the trailer work fine when hooked directly to a 12 volt battery.
So I think if I buy a standard 30 or 40 amp auto relay it would solve the issue, anyone think so too????
