Can anyone tell me what kind of wood or other material is used for transducer fairing or leveling blocks. I dove under to clean bottom and noticed the blocks are pretty bad. Getting it hauled out on Friday.
Thanks in advance
Al
I'd venture the vast majority of installations of protruding T/h T/d's these days employ long-life, high-impact plastic fairing blocks. For planing hulls the sleek High-Speed fairing blocks provide much better results than the clunkier Standard versions.
If your T/d's are Airmar-made and look like one of these http://airmartechnology.com/airmar2005/ex20/RMProducts/OpenData.asp , click on "more", then the "Cross-Reference" link at left. The chart should show a fairng block part # at the R. If any question as to whether it is the HS version, try giving Airmar a buzz.
Airmar makes a really good fairing block and can be trimmed and shaped to work with almost any transducer. I replaced my old block this Spring with the Airmar and used a Dremmel tool to reshape the pocket to fit my transducer. Works like a charm!
