Transducer Paint
GrecRI
For some odd reason, the marine stores in this area all seem to be out of transducer paint. I know you aren't supposed to use normal bottom paint on the transducer face.
Is it okay to use outdrive anti-fouling on it?
Current guidance from the depthsounder manufacturers is: NO paint on the transducer face. Just scrub it periodically with a brush or use detergent-water mix if it is on a trailer. Keep the face clean as possible to get maximum resolution and depth range.
erie_guy
Port Clinton, OH
I've used conventional bottom paint for the last 30 years. Look at the labels.....They both contain cuprous oxide. What's the difference? I apply 2 very thin coats. Depth finder has worked fine from day one!
I paint mine when I paint hull. Lowrance rep said it was o.k. I get readings to 900'. Some people mount transducer to inside of boat. Shooting through hull.Works fine going through bottom paint that way,right?
Good points. I don't want to leave it bare because it's mounted low enough where I would have to take a swim in order to clean it. That's okay in the summer, but I leave the boat in the water well into the Fall. November in RI is not exactly swim-friendly. ;)
The difference is the solvents in the paint, not the copper. If you use a paint with a solvent that attacks the plastic or urethane transducer face/cable, you're in for some problems. It could dissolve the PVC cable jacket or turn the transducer into a stick, gooey mess.
Airmar specifically says use a water-based paint and avoid ketone-based solvents.
