Transducer Reading
Brian
Will the depth finder show a reading when the boat is on the hard. I was checking different things before going in the water. No reading for depth.
Thanks Les...now that you pointed that out. On my part DUH
Sometimes they will, if the surface is hard and not too far away (a foot or so). It won't be correct though.
Sonar works in air... bats use it all the time. Any time you make a noise and hear an echo, that's sonar.
Sometimes you can actually hear the clicks from a transom-mount transducer. At least with my Humminbird. They're faint, but they're there.
The boat is now in the water. I hear the clicking but I didn't get a reading then it started to read but was flashing and I checked the options to make sure the flashing was off. Th manual says if it is flashing it is because it can't "see" the bottom but yet it shows me a depth. Then the reading will go away. It does read temps. It is a Garmin 178. The transducer is a thru hull. Bad transducer??
Funny, I was going to ask a similar question. I installed a new transducer, Airmar DT800, and turned it on while on the hard. The unit said there was 11' of depth but the actual depth from hull to ground was closer to 2-3 feet. Temp reading was correct. Hopefully the depth will read correctly in the water.
As for the depth reading coming and going -- is the transducer forward of all running gear? Something to consider.
Willie is correct, you will, at times, get a reading from your sounder while the boat is on the hard. But, it will be nowhere near correct since sound travels at vastly different speeds through air as opposed to water. Your sounder is calibrated for speed of sound through water.
The flashing and inconsistent readings sound like you may have a settings configuration problem. Most sounders will flash if you are in very shallow water and the settings are for warnings at that depth. Go through all of your "menus" and make sure your set up correctly. Transducers are really very simple instruments and while a bad one is not impossible, usually it's a user problem or a problem with the head rather than the transducer. If, after checking it all out, the problem persists you may need to consult a pro or the factory tech rep.
Originally posted by Brian
Be careful running depthsounders in the air. They can and do get hot. This might cause a failure.
Plus you might get horny bats looking for a good time...
