Transmission gear while sailing
Tugger
Does anyone know what gear I should use when I am under sail and my Perkins 4-108 is off. I am worried that in neutral the prop will turn the engine.
There was a study done about 20 years ago by something like MIT. It was published and reviwed in Practical Sailor magazine. The issue was whether to leave the engine in neutral or fixed in gear while travelling under sail. They were primrily intrerested in the increase/decrease in boat speed with the consideration of prop drag.
As I remember there was very little difference in boat speed one way or the other. Maybe there has been a more recent study with different results.
Funny Joe I remember a study showing more drag from a spinning prop. Must be the mad cow.
I believe most transmissions need to have the engine running to pressurize the transmission clutch plates to have any effect on the propshaft or vice versa-i.e., engine ,off, keeping tranny in fwd or rev will not lock the shaft and will not turn the engine, so unless you have an independent shaft lock you might as well just keep it in neutral to minimize drag.
Some transmissions apparently can be harmed by free-wheeling over a certain speed as heat builds up but the engine RW pump is not cooling the tranny cooler, but I'd imagine your sailboat would be set up to handle this at hull speed. If that is not the case it would likely have a shaft lock I'd imagine. Also some propshaft dripless seals "might" not get proper cooling normally provided by the RW pump and wear over time.
Does your boat have a variable pitch or an auto-feathering sailboat prop?
Bruce , you might well be right but that's a hard concept to get my head around & around since the prop wants to turn REALLY BADLY. :D Still, in the old war movies , when the bomber engine went out the props would lock into position as I recall. But then again , they had feathering props I think, so a locked prop at 0 pitch is likely optimum, yes??
Originally posted by Tugger
If the transmission is in neutral how can the prop turn the engine. Is not the definition of neutral that the engine is disconnected from the prop (drive wheels)?
G
I think you misunderstood Tugger's post. In neutral it won't turn the engine, but a hydraulic transmission without the engine running to provide hydraulic pressure is not going to engage, regardless of what gear you put it in. Only a manual transmission is positive. Suggest Tugger that you identify the transmission you have and contact the mfgr.
Drag depends a lot on the type of prop. A big-bladed powerboat prop MAY have less drag if allowed to spin; a skinny sailboat prop probably has less drag when it's locked and is not presenting a full disk to the water flow. There are so many variables (hull shape, prop shape, system friction, etc) that probably the only way to know for sure with YOUR boat is to go sailing.
i do not believe its possible to spin the engine over using a typical sail boat prop (perkins diesel)unless the compression release is on or hes being towed about 30 mph. most sail boats do not have hydro transmissions they just crash the gears togather like an outboard
Bruce:
I remember reading the article and it had tons of techical, mathematical and physics terms which eluded me, and would still do so.
The little bit of English I could understand let me to the minor difference conclusion. Even with the published article that I showed to fellow racers, the fixed prop-max speed theory gang remained convinced that locked was better.
I think that they still do. I never pursued it further since my engine was pulled before the races.
There must be a more current study...in English.
Many thanks. I will check with the engine manuf. I also have a packing box that works with water pressure coming from the engine, so I expect that keeping the prop locked is the best approach.
i recall reading a study about this specific question and the results were that a spinning prop had more drag than a stationary one. unless it is a large sailboat with a fancy transmission the prop will most likely not turn while in gear. it has to be less wear on anything with the prop not turning. i'm sure the difference in drag would be unmeasurable except in the lightest of air.
