Transmission Noise Normal?
David M
Went out this weekend for a few hours. The boat performed pretty well. I noticed the starboard transmission is louder than the port, particularly in reverse. It has always been this way, however this time it just seemed louder to me. The weather was over 100*F with damn near 100% humidity. Perhaps that was exascerbating the noise. I don't know.
I can barely tell if the port transmission is going into or out of gear in forward or reverse. It's just that quiet. The starboard on the other hand whines when going into gear and climbing onto plane. There is a lot of vibration in reverse. The engines are within specs for alignment. There is no vibration in forward. Shafts were redone after a log strike in 2007 and the props were Propscanned by Wildcat Propellors in 2009.
Could any of this due to the fact both engines are normal automobile rotation and the transmission has to reverse one prop?
Both transmissions fluid is pink with no visible sign or smell of something wrong.
TIA
I have Walter V Drives and the starboard drive has always been noisier because of the counter rotation gear.
Also, check your shaft collar zincs. If one is loose it will most often rattle when in reverse. Drive line noise is really tricky to pin point in that it telegraphs like crazy.
I would first check the collar zincs. If that isn't it get a mechanics stethascope and find the actual source of the vibration/noise.
Depending on the wind, i hear one rattle and one not.
Plus Since on my boat I can only see down port side becuase of the flybridge, I typically only hear the port one rattle. Mine rattle in reverse. Told this is normal!
Yes.. I experience the same thing with my 330 and was told it is a normal thing for ZF Hurth Transmissions.
