We have almost solved the trim tab wiring issues in this thread: "LINK"
I have a question about the shape of the tab itself. Saint Max and other 330's I have seen on the hard have tabs shaped sort of like this:
Sorry, can't do pix from here.
This would be the port tab looking at the boat from the stern.
I have seen newer Sea Ray's with flat tabs and older Wellcraft with flat tabs.
I was wondering if the 90* down angle is a help or a hinderence to effeciency. In that I am adding an extension to my tabs, would I be better served having the 90* bend lessened to say 45* or 60* like this:
Or should I remove it altogether.
I spoke to tabman many moons ago. He told me the new (then) Sport Tab system's design gave 16% greater lift than a flat tab. The sport tab has a 90* down bend on each side of the tab and a slight up angle (don't know how many degrees) from the center. The 90* down angle when viewed from the side looks like a 30/60/90 triangle with the short leg aft, the long leg parallel the tab chord and the 30* angle of the hypoteneuse forward and the 60* angle aft and down.
I know from reading an article on the MY Mephistopholes many years ago that what works for little boats will not necessarily apply on bigger boats.
In that Saint Max will be on the hard and the extensions are going on regardless, what say you gurus regarding the best bang for the buck at the welding shop?
Any and all comments welcome.
TIA
TIA
