Trouble getting on Plane:
carver 2557
Would Trim tabs help?..
A quick hunt revealed that RollyCraft the operator is frankly relishing is the 27' Water Weenie, apparently somewhere in Michigan (was at the 2010 Detroit Boat Show). What are the odds the captain's name is either Oscar or Nathan.....
Here's how you too can make your own hot dog boat :
http://doublebflat.blogspot.com/2011/08/weiner-boats.html [;D]
Naw, it is the "deli" mustard and pickle relish that is causing the problem. I'll bet yellow mustard and sourkraut will get it right up on top. If it is Hebrew National, it would "answer to a higher authority" and Fenway Franks always require you to wait until next year!
Gene
carver, is that YOU???? Maybe the skipper needs to lighten his load a bit, as in lose some weight!
