Truck davit
BJL
I'm thinking of getting one of these to use to lift our inflatable in/out at our dock. Costs much less than a marine davit and I think it would work. Any thoughts?
Will you be able to secure the base good enough to the dock, I would think that would be the hardest thing to accomplish... other than that, I think it would work fine.
I used the very same thing to lift the jet skis. It was attached to the bulkhead piling with thru bolts and stainless backing plate.
A friend just installed one in his truck for lifting buckets of lead wheel weights to be converted into lead sinkers. He got it at Harbor Freight and it works quite well. As others have said, be sure to mount it with a backing plate and keep everything well lubed to avoid rust.
Kelly G, where'd you get yours? I see you live on Long Island as I do. I've only seem them advertised on Ebay.......did you find one locally or on the internet and how much (if you don't mind me asking) did it cost? I can't bolt it with any backing plate but I doubt that would be a problem. Our whips are mounted on the bulkhead edge and hold just fine. This lift wouldn't be lifting more than 125 lbs. and that would only be occasionally.
Bumping this up again and hope Kelly G replies! Would love to know where you purchased the davit.
Trying to get the photo to show:
Barbara..... There's a company in N.J. called Monarch Mooring Whips...aka Monarch Marine....(do a google search)....that make a real nice all alum. PWC lift that bolts to your piling and has a 800+ lb ( 120vac) lift capacity. I think it may be available in 12vdc ...for your truck also.
I've had mine for 9 years now and the only issue was the need to replace the cable. I used it for my 650lb. jet ski years ago.....now I use it to lower the dinghy down to the boat. They will ship direct to your house....and take C/C over the phone. If you call ask to speak with Don Jr. ..... he's the Long Island rep.
Good Luck........
Don, I've dealt with Monarch several times (I have their whips and some accessories). Great company and great customer service but their davits are more than I need or want to pay for. The one I posted the pic of is less than $200. I don't need it for a truck, only for the inflatable or hard dinghy from the dock to the water and I'm not even sure how often I'd really have to use it so I don't want to spend a bundle on overkill. Don't even need anything more than a manual winch! Thanks anyway..............hey, ya never know! By the way, the owner and son of the company are both named Don!
Dave, looks like the same one. Thanks, I'll keep that site on file in case I decide to get one!
