The tuffsew, thomson, sailrite and a few other portable walking foot machines are all made in china and are of questionable quality. However, the sailrite machine is upgraded by sailrite and has a much better reputation and very good customer service, but with the sailrite machine, you'll be into it for $800-1000 by the time your finished buying all the add-ons. For that price you can probably buy a used juki or consew. If you need a portable machine, the sailrite is probably the best out there. However,if I was spending that amount of money, I'd go for a machine like Starry Night has. I picked up a vintage singer for almost nothing and it did the job for me. I had a couple of thick areas and had to hand crank the machine through them, but I'm not doing a lot of canvas work here, just some small projects. Charlie, you can slow your 281 down and increase power with a speed reducer, which is a pulley system that you mount under the machine. Also, maybe Starry Night can verify this, but when you replace your isenglass, you don't cut out the old stuff, you sew new isenglass over it and then cut the old stuff out from the front in order to keep the shape of the panel.
