Turning off a Twin
Greg Schoenberg
For helm speed (5-7 knots), is shutting down one twin engine, then running the other (switching back and forth each half hour) more fuel efficient than running both twins at that speed??
Boat is a 30 ft. Carver with 220hp Crusader gassers.
-Greg
Don't know, but if the prop is spinning on the shut down motor I believe you can mess up your gear set because it's turning and not getting cooling water and if you have dripless shaft seals they can get whacked w/o cooling water.
I switch back and forth when on the canal. I'm not sure if i'm saving any gas. I'd like to think i am. :)
Wild guess, but if you are below hull speed (probably about 5 kt-6 kts on your boat) then running both should be no less efficient and possibly more efficient than running on one. The basis is the amount of energy to move the boat through the water is speed dependent. So the question then becomes the most efficient way to deliver the energy. In addition to the mechanical issues of gears, you have also increased drag from a non-powered prop if on one, and you have to overcome a yaw effect which also probably increases drag.
folks:
listen to partyTime. You can damage your shaft seals (v-drives) by spinning the shaft without cooling water.
ok so the solution would be to place it in gear when using only one engine. In the navy we called it placing the shaft on the jack and then locking the shaft. By placing it in gear while the engine is shut down would prevent the shaft form rotating and the small amount of pressure placed on the blades is insignificant compared to the torque when the engine is running. and while I agree with the energy used for hull speed is figurable with an equation. a running engine consumes an amount of fuel even at idle. I think at low speeds one uses less than two anyday. especially when you take in concideration most engines are more eficient around 1/3 thottle and not as eficient near idle.
Some transmissions are sensitive to freewheeling, but most can take hours before risking any sort of damage, and even then a short start up is often enough to lube them up again. This is slow speed turning after all.
As far as the efficiency, producing less power is what causes fuel consumption to go down, not just using one engine. You are really splicing hairs trying to measure the difference in efficiency by producing the same propulsion with one engine instead of two. Running 6 knots is going to take roughly the same amount of power, whether it is produced by one engine or two.
Where you end up running one engine is where you don't have enough load on two engines to maintain adequate temps on the engines. This is a more common problem with diesels.
Check to see that your engines are staying up to sufficient minimum temps. If so, you are likely better off running on two engines, even at slow speed. Again, I think you would be hard pressed to measure any efficiency difference between one engine or two, given that the same boat speed was maintained. Splicing hairs. All the value is simply from slowing down. Not to mention the drag produced by a locked down prop.
I run my 3208's at 9 knots nearly 95% of the time. I get 2.3 mpg. Beat that for a 48 foot boat!
Yup, some of trans can free wheel without a problem. I have Borg Warner 5000 Velvet Drives, Owner's manual says they can freewheel without damage. Check your manual.
its been long established by sailors that a free wheeling prop is more drag than a fixed one, i don't know if that holds true on larger wheels, but logic would tell you that it would.
a single engine boat and a dual engine boat of equal horsepower do not have equal fuel consumption, the single engine boat is always more effecient at cruising speed. if this were not the case all ocean freighters would be configured with dual engines or more. most vessels are equiped with dual engines because of handling and redundancy/safety.
if you have dual engines and want to move at anything faster than hull speed you will be overloading the motor, but at hull speed or less there is a fuel savings to be had. how much savings is open to debate. without some very accurate fuel consumption data its hard to say hom much can be saved. in the big picture it will lower the hours of usage significantly by running alternate engines if you travel great distance at slow speed. and that has an economic value as well.
if you choose to travel with one motor and it is an I/O, do not back down without at least starting the 2nd motor. this is necc. to avoid possibly ingesting water back up thru the exhaust and into the motor.
I guess you could run some tests to determine fuel useage but I'm pretty sure that over 100 miles with identical current and wind you will find that the single engine scenario may save you a quart or two of fuel. And yes there is a significant yaw effect at 5-7 mph using only one engine, that is why you can steer a twin screw boat without ever touching the steering wheel, just shifting the engines in gear and out. So my opinion is that any fuel savings unless crossing the Atlantic is insignificant. Besides, you would need to factor in the additional engine wear of continually starting and coming up to temp then shutting down, and the additional wear on the starter moter itself.
rudder size, prop spacing and bottom shape affect the amount of yaw thats why all the generalizations dont work but in general if you cant steer you are going too fast.
My inclination is that at low rpms say 1800 or less on a gas engine, there will be some fuel savings. The engine that is running will burn more fuel than it would if both engines were running, but less than the amount consumed by both engines. For example (note: these are not actual numbers). Running at 10 mph on 2 engines. Each one is using 3 gallons per hour or 6 gallons per hour combined. Runing on a single enngine the consumption may be 5 gallons per hour.
Each engine, outdrive, and transmission has moving parts. Moving parts create friction. The less moving parts the less friction. Double the moving parts by running 2 engines creates twice the friction. Fuel has to be consumed to overcome this. So was doesn't the fuel milage double? Because a bigger load is put on the single engine that is running and it may have to run a few hundred rpm's higher to achieve the same speed. The higher the rpm's the more times the friction is applied. A good example is looking a a big, long freight trains. One with several engines. Normally they only operate on one or two. If it were more effiecient they would run all of them. I imagine they use the others engines only when needed.
The problem is you need to put the helm over a fair bit keep tracking straight. This will direct the thrust to the side and reduce the efficiency of the propulsion. with both engines in gear they are directing their thrust directly astern which is more effecient in propelling the vessel forward.
anyone who has ever experimented with twins quickly observes that below the speed where the bow lifts shutting off one engine makes little difference in speed and that can be easily recovered by a small increase in rpms on the operating engine. This leads to this discussion and a request for folks to do actual experiments instead of speculation. We have one data point already how about some others??
http://www.boatered.com/forum/topic.asp?TOPIC_ID=115284
No fuel data to report but I did consult with my charter co. mechanic and he said there is some savings. He emphasized, for my tranny, that it be put in gear. We experimented a bit through a no-wake zone, shutting down the port engine for a mile. It required little helm control...no significant yawing. There was a difference of 2-300 rpm's to maintain 6 mph. So...given this, there must be some savings.
I don't plan to employ this much. On my boat, helm speed is a pain if there is current or wind.
-Greg
