U S District Judge Oliver Wanger
"Remember when U. S. District Judge Oliver Wanger found the Biological Opinions were inadequate to protect fish in the Delta? He ordered export reductions while fishery agencies went back to redo the BiOps, and exporters had a long, noisy fit.
The new BiOps require nearly the same export restrictions to protect fish. Now Wanger doesn't find enough science there to support decreased exports.
Last week, Wanger decided that water officials must consider humans along with fish in limiting use of the Delta for irrigation. The arguments of urban and agricultural water users convinced him that the federal government's science didn't prove increased pumping from the Delta imperiled salmon.
Wanger followed that decision with another this week that lifted pumping restrictions designed to help endangered salmon. Urban and agricultural water users argued that these restriction could be lifted without harming the fish. The order will be in place until June 15.
As of this writing, pumping restrictions to protect smelt remain in place. According to John Ellis, reporting in the Fresno Bee, users have focused on the salmon restrictions because they are less onerous than those for smelt. But Tom Birmingham, general manager of Westlands Water District, admits that continued smelt restrictions could cancel any water delivery gains resulting from lifting the salmon restrictions.
Writes Ellis, "Wanger also ordered federal officials to monitor the increased pumping. If more endangered spring-run Chinook salmon or Central Valley steelhead are found around the pumps or being killed by them, the federal government or environmental groups can ask Wanger to reverse his ruling." But at this point, "most of the endangered spring-run Chinook salmon and Central Valley steelhead had already passed through the Delta and out to the Pacific Ocean."
To some, this looks like the same plan for operation that Wanger invalidated in the previous salmon management plan because it jeopardized the species."
restorethedelta.com
The saga continues........
"And what will they do with that water?
Wanger's decisions means that Westlands water users will get about 10% more irrigation water for the next 20 days.
Cropping decisions were made last fall. So some of the water available now will be stored at San Luis Reservoir for future use.
KFSN in Fresno interviewed Kerman almond and cotton grower Paul Betancourt. Said Betancourt, "The immediate change won't be in acres planted but it will be in groundwater pumped. The quality of surface water is much higher than groundwater so we can use the surface water. Get some of these salts flushed out of the soils."
Wait! You mean you have salts in your soil?"
restorethedelta.com
I guess he was holding out for a bigger payout from the water interests with all the money.
