unidentified alarm
dairel
We made our first run out to the bay yesterday on our new (for us) 2005 Mainship 400 w/twin Yanmars.
At the mouth of the Patapsco, an alarm sounded (steady alarm, no beeping). I immediately throttled her back to idle. No warning message appeared on our Raymarine E80, and no warning lights lit (I know they work). Water temperature, oil pressure both seemed fine. I ran around the vessel and checked the engine room and bilges and saw no problems.
After about 10 minutes the alarm quit on its own, and the boat behaved just fine all the way back to the marina, running most of the way at 15MPH / 2800 RPM.
Any ideas?
It seems that you've covered the most obvious. It would be easiest to check the electronics first, then the oil pressure, to me would be the # 1 consideration followed closely by the H2O temperature and/or transmission oil pressure.
Question? Were you running the same RPMs going out as returning, or slower going back in?
This is one of those quirks that doing nothing may be OK, and doing lots may prove that there's nothing wrong. But, this, in my mind, would be the most prudent avenue to take. It would seem to me that you'd wish to check the oil pressure with a mechanical oil-pressure gauge. You might also wish to check the engines overall, including the transmissions while you're at it, with an infra-red temp. sensor.
It's the "After about 10 minutes the alarm quit on its own" that has me thinking H2O or something heat related.
Yes, we came back in at around the same speed. I was thinking something temperature or pressure related too, but water was showing 175 deg and oil pressure was ~75PSI on each engine. During our survey (3 engine hours ago) the surveyor had a heat gun on both engines for 30 minutes and they both ran fine.
It wasn't the CO sensor -- that was one of the things I checked.
I thought about the GPS (there was an article in the Balt Sun this week about GPS signals going out this summer on the Chesapeake).
But the GPS seemed to be tracking properly as we moved (at least it looked that way to me on the plotter).
Very weird (and a little disconcerting).
Were you able to identify where the alarm was coming from?
Do you have a dual helm?
What type of shift/throttle control do you have?
I have a Morse electronic control. For redundency purposes it has two 12v feeds which are supposed to connect to two different battery systems. If either 12 volt input drops below the acceptable level an alarm goes off. Unfortunately, the alarm buzzer is stuffed up under the dash some place and not on the control unit so if you were unfamiliar with it you wouldn't associate the alarm with the shifter/throttle control.
Rod
High bilge water alarm? Some boats have a second float switch that triggers an alarm.
Had a similar situation once, turned out to be the alarm on the Racor fuel filter indicating there was water in the bowl which needed to be drained. I think there's an indicator light also if you have the alarm, but not obvious if you aren't looking for it.
We had Tstorm warnings that day. What does the weather alarm on your radio sound like?
Do you have a thruster? Some sound an alarm before they shut themselves off.
Didn't think about the bilge switch (jammed or faulty) or a fuel filter, I'll check those this weekend.
I doubt it was weather related, we were out pretty early, well before any bad weather was anywhere near Baltimore.
Don't know the answer on the throttle. It is a dual-helm boat, and the controls are not electronic (ie not Gledinning). No thrusters.
Are ghosts a possibility?
