Using the outdrive to board
mrknowitall
I was at the lake on vacation this week and saw the same thing happen more than once. Skier needed to board the boat, helmsman leaves the engine running turns and watches the skier step on the outdrive to board. Wow... I said to my friends. No way was the response. Sure looked like a bad practice given how easy it would be to knock it in gear with a bee flying around your head or an unexpected wave slapping the hull. Hummmm, not on my watch. I am a knowitall but I didn't say anything. What would you do?
Not that! I do have to use the outdrive to reach the first step of my swim ladder, but never with the engine on.
Some people think (?) that Darwin Awards are for scientific achievement.
I and many others with outboards use the tilt button to raise the motor like an elevator. Just step right aboard in a bass boat. BUT THE ENGINE IS OFF!!!
Of course not running, but there was a note in a recent post that climbing on a Doel-Fin or similar device might cause the cavitation plate to break at a bolt hole. Never happened to me, but it seems to have on this forum.
Slipping off the cav plate and into a stainless prop could be painful too.
Even with the engine off, isn't it possible to slip off the top of the drive on some marine growth and cut yourslef on the prop?
Engine/engines off when someone is in the water, no one ever on the swim platform with engines running.
No one ever uses my outdrive to step on...it seems like a very expensive "step." There is no need to get near mine when boarding and if I had a ladder that was not sufficient, I would buy one that was. And yeah...absolutely no one on the swim platform with the boat running except the Admiral at docking time with the boat going very slowly.
I too have seen this many times. The idea that the boat is in neutral makes it completely safe I guess is the logic. I'm a middle aged skier and have been as temped as any to use the out drive as a lower step to aid in getting up on the ladder. But I refuse to allow myself or anyone else to do it. I have always been afriad that the outdrive isn't designed to support that type of load and that it may damage something. Especially on an older boat like mine. Is this a valid fear or is the weight pushing down on the gimble etc. not an issue?
it's been a while since i had an Stern drive but i used it as a step for years, especially on the hard. if the drive can withstands 300 hp applied to the prop.. i think it can put up with 200lbs of weight...
never slipped off it either.
now with the engine running... that's a stupid idea but i've seen more stupid things on the water :-)
Unless you weigh well over 1000 lbs, I don't see how it can possibly hurt the drive. After all, how much force is on it when you're running? Even my little 115 puts a lot more pressure on the entire drive mechanism than my 200 lbs. And when I'm running along about 60 MPH, the trim cylinders holding that entire motor at an angle is supporting way more than my 200 lbs.
And Doel-fin type products are known for causing cav plate problems, so DO NOT step on one. And if you need one, you actually need a bigger motor.
I don't think you'll hurt the drive; when I had a sailboat I used my 9.9 outboard to board. However a PROPER boarding ladder is far easier and safer, and worth the investment. And SHUT THE MOTOR OFF!
IMO
Most pleasure cruisers simply do not spend enough time / thought on re-boarding devices.
Lack of that can be deadly.
For the new to boating guys any way please spend some time and thought into a safe / reliable / proven set up. That will get you aboard safely in the conditions you boat.
I learn the hard way < grin >
Willy
my favorite boarding ladder are those that mount under the swimplatform. they're out of the way, out of sight and can be deployed from the water.
some newer boats have thicker integral swim platform and in some cases the ladder is on top, covered by a hatch. if you have one of these, make sure that you can lift the hatch and unfold the ladder from the water.
I wanted to give some advise about the danger of leaving the engine running... but most peole don't want to hear about it. I feel guilty that someone could get hurt, yet I said nothing.
I'll second that Pascal. I fell off the boat this winter, fully clothed and into 42 degree water. In the summer, I can palm the swim platform and hoist myself out, but I couldn't even get close under those conditions (but I was foolish enough to try a few times.) Instead, I had to swim to the ladder and lift the cover up about 160 degs before it'll rest against the transom, then the fwd edge of ladder has to be lifted up and back, then extended. By the time I accomplished all that, I was starting to lose muscle control. On top of all that, the well that the ladder lives in within the platform is always collecting dirt. It's a very dumb design.
(and yes, the ladder spent the rest of the winter season fully-extended in the water)
I agree also with Pascal with a but. That style can become useless if you are using the swimplatform to store / transport your tender. Just a heads up.
Man like SLW states it takes but a few min for the cold water to take your strenght away.
Also for what ever reason too many people will not scream for help when faced with this situation ( not being able to re-board ). Please SCREAM as loud as you can for help while you still can. You will get over that.
Man I sound like an old fart LOL.
Willy
well, the nice thing about an under platform ladder is that you can also mount it at the end, on the side of the platform if you have a stern mounted dink !
That is a great point about making sure that you can deploy the swim ladder from the water. I know that I could with my last boat, but I'm not positive with this new boat. I do know that the way in which I dock my boat at the marina (stern in), that I could not deploy the ladder if I were to fall in at the marina. I would hope though that I could shimmy my fat %$rb2@gr5t up using the flotation devices and metal on the dock. Or (ironically) use the outdrive.
I wonder if there is a ladder made for emergencies only that you could mount under your swim platform. Sort of like the fire ladders they sell that are stay folded up until you throw them out the window. The only problem is what would it "grab" on to to.
