Vapor detector too sensitive?
jaj63207
The vapor detector in my Carver alarms if the boat has been sitting for days with out running. I open the hatches, crawl in an can smell nothing. Visually all fuel fittings and carbs and the intake manifold are dry. If I run the bilge blowers for a minute or so the alarm goes from danger to safe. After about 10 minutes, it starts alarming intermittently. I would really like to use the alarm, but all indications are it is too sensitive or sniffing paint odors or something. Any thoughts?
Jimmy
How old is the sensor? I would try replacing the sensor first, or possibly reposition it.
I am guessing its as old as the boat(1986). I might do that. I certainly feel more secure knowing whats happening under the living room floor.Thanks
If you have enough cable try the sensor outside of the bilge. If it doesn't alarm you may actually have problem, if it is still alarming I would guess you have a faulty sensor I assume it worked at some point?
I have the same problem in my 43 carver but it's a newer detector, curious to see what people have to say here
I sanded and repainted my motor mounts a couple months ago. The only smell I detect is a little paint smell. Wonder if that might be doing it.
Jimmy
Yes, paint, almost anything of a chemical nature, can fire off the alarm. It wouldn't hurt to replace the sensor unit since yours is old, but I bet after a few months the paint will stop emitting fumes and you'll be ok. Maybe you should leave the engine hatch open during the week to speed up the elimination of fumes from the paint.
Don't disarm your detector and don't ignore it when it goes off. My detector first runs the blowers. If the fumes don't quickly clear, it sets off the alarm. I have NEVER had a false alarm.
