Variation on Battery Questions
speedo
Moderator
I have two, two-battery banks, 12v running parallel. Bank 1 is fine, bank 2 showed an error while charging. Disconnected batteries in bank 2 from each other and put charger only on battery 1. Error code. Put charger on battery 2, it's now fully charged.
If bank 2 works OK with one battery, is there any harm in just replacing the one battery that's bad, and going back to two batteries in the bank. Or should I replace both in the bank right now, regardless of how the remaining battery performs by itself?
Thanks!
All batteries in a bank should be as near to identical as possible. So "can you replace one of the batteries in a bank while not replacing the other?" Yes, but it is not recommended. You should always replace all batteries in a bank at the same time.
