- Sep 16, 2003
- 12212
- 12,183
came across something interesting yesterday (not on my boat)
boat with 4 Vacuflushes (nice electronic models where you press a little lever just like a home toilet sending a some water in before a servo motor opens the ball valve)...
Each head has a Y valve under the nearby sink (unlocked... yikes) and also had a vented loop between the vac pump and the Y valve. on a couple of flushes we smelled "something"...
seems to me that the set up is wrong and that when flushing one head to the holding tank, air could be coming out of the vented loop on one or more of the other heads.
There is no need for vented loops with VF going to a holding tank, only for overboard discharge. It looks like the loop should be AFTER and not before the Y valve to be totally out of the picture in normal near shore/inland operations.
doens't seem hard to swap it around, any thoughts before this goes on the boat to do list? Vic?
