VHF reception problems may be caused by a number of items including:
¡Rado has been configured to "Local" mode
¡low battery level
¡poor/corroded radio power leads
¡insufficient power wire guage
¡incorrectly configured squelch
¡a failure of the VHF antenna
¡a failure of VHF antenna cable
¡corrosion and/or failure of the antenna's PL-259 connector
¡a failure of the antenna splitter
¡a failure within the VHF radio itself
Before sending one's VHF radio in for service, one may fault isolate the problem by:
¡verifying that the radio has been configured for "Distant" rather than "Local" mode
¡fully charging the batteries and then attempt to duplicate the problem while the vessel is connected to shore power
¡inspecting the power connections between the radio and power distribution panel for tight, electrically sound connections which are free of corrosion.
¡inspecting the power connections between the batteries and the electrical distribution panel for tight, electrically sound connections which are free of corrosion.
¡inspecting the guage of wire used for extending the VHF radio power leads and the wires supplying power to the power distribution panel. Infromation addressing how to select the correct gauge wire is available from the ABYC, NMEA and other sources.
¡verifying that the VHF radio's Squelch setting has been reduced to a level slightly above that which produces static to be heard when no other station is transmitting
¡inspecting the VHF cable for kinks, sharp radius bends, or other signs of damage
¡inspecting the antenna's PL-259 connector for sign of corrosion, damage to the center conductor, or poor shield connection
¡testing the currently installed VHF antenna using a VSWR meter or testing the VHF radio using another VHF antenna.
Note: If the vessel is not already outfitted with second VHF antenna or an emergency VHF antenna, then it is recommended that the vessel be so outfitted for safety purposes.
Should the above listed tests not identify a problem with the power supplied, radio configuration settings squelch, or VHF antenna, then the VHF radio should be sent to Raymarine's Product Repair Center to be serviced. Raymarine VHF radios carry a 3-year warranty from the date of purchase. For VHF radios which are no longer covered by warranty, Raymarine's web site includes information for out of warranty VHF radio repairs.
Whereas VHF radios are considered a primary item of boating safety equipment, Raymarine recommends regular inspection and testing of VHF radios by their owners. Raymarine recommends that prior to each journey, the vessel operator perform a routine Ship to Ship or Ship to Shore call to ensure that the vessel's VHF communications system is functioning properly. Vessels equipped with a DSC VHF radio should ensure that the radio is being supplied with the vessel's lat/lon coordinates when testing the VHF communications system.
