VHF Radio question?????
jdshep
NonCommerical channels 9,68,69,71,72,78,79,80 .
Question are these the channels I would use to talk to another boat? If not what channels? I have the FCC Marine VHF Radio Channels which i used for the above list.
Thanks in advance
John d
I would not include ch9, but I believe the others are all available as non commercial channels. I usually use 68, 69, 71, 72 as well as 16.
John,
Pascal had a thread of Jan 21 called "VHF Usage" that had LOT's of good information....I'm still learning
It is expected, in fact I think that there are words to that effect in the FCC rules, that IF a VHF radio is in use a vessel should monitor channel 16. Ships larger than 20 meters are also required to monitor channel 13.
To this end you will find that most modern VHF marine radios will power on set to channel 16, and many have a single button return to channel 16.
So, if you see another small boat that you wish to hail, call them on channel 16. Likewise, keep your radio on channel 16 so others can hail you. On the other hand, if you really need to hail a large ship, call them on channel 13.
Once you establish contact then you can switch to one of the working channels. Any of those you listed, except for channel 9, could be used.
In many areas channel 9 is used for special purposes. In the California delta, for example, all the bridges monitor channel 9. If you need the bridge to open call them on channel 9, not channel 16. The use of channel 9 certainly varies with location so you need to get local information.
Be advised that if you switch to channel 13 or 67 your radio will automatcially reduce power to 1 watt (normal power is 25 watts for a fixed mount radio)
