Vinyl Lettering
sevo
The Logo/Lettering for the new boat was $75. They want $250 more to install it! If they guaranteed they wouldn't be 3 hours late like last time I might consider it.
Anyone have any good tricks for do-it-yourself lettering installation?
Ordered mine on line. Wanted to keep it simple but there are a lot of customizations you can order. Then just follow their directions. Been on for 2 years and holing up well. I think my total cost was $48. Needed to people to apply it on and it took about and hour.
Theres no tricks to installing it, just draw a straight line and center it. Most of the companies inline give you instructions and a squeegy to install it. They have boat lettering all over the internet. Try Ebay theres a few there.
Clean it with acetone, clean it with acetone again with a fresh rag, wipe it again with acetone with a fresh rag. Don't try it in direct sunlight or high heat. Spray it down with Windex and leave the Windex there, it'll leave you some leeway to shift the vinyl if need be (which WILL be). Don't fret, it all squeegees out and doesn't affect adhesion.
I used a similar trick like Mike...
a little dishsoap + water in a spray bottle on a clean surface (use the shade). Peel the adhesive and spray it too. Put 'er on the transom and move it where you want it with respect to your lines. Squeegie out the residue. Allow to dry. Peel off the template layers. Wala! Professional job without the expense.
You can do this!
It's easy. Follow the advice above (Clean, clean clean) and what the manufacturer provides. I bought mine online for $72 and installed in an hour. Save yourself the hassle of someone else and learn from it.
Someone that I trust told me to never use acetone. You that use it, what's the secret to using it successfully?
I put it liberally on a clean rag, but not dripping. Use the rag to wipe your surfaces clean, and this will remove the wax too. Don't spill the stuff. If you do, clean it up quickly. Be careful around plastics. I have used it sparingly to shine up rub rails but too much and you create a real esthetic mess of the rail surface.
It's perfect for the cleaning prep job you want. Just don't clean off your premarked stencil guidelines so you can get the lettering on straight. Go for it!
Use the cleaning solutions that the manufacturer recommends. I got mine from BoatUS and they recommended diluted rubbing alchohol for prep and a mild soap solution spray for application with the squeegee. Mine was a 2-piece overlay: textured gold leaf on black border vinyl. Measure carefully before you order. I marked with with blue tape before application. Mine measured 40.5" X 11.75" and 20" X 4" and took about 1 1/2 hrs. to apply. It's a wooden boat so a couple of days later the whole thing got a couple of varnish coats on top.
Hi guys, I have been a member on this board for a while and I would never self promote or spam so if it is not ok to post this just remove. I just thought it might be helpful. If you would like sevo I can make up vinyl lettering for you and give you instructions as well as a squeegee. Most all the vinyl work I do the buyer installs and I have never had a complaint. If interested just send me an IM.
Best,
Robert
The trick to using acetone on gelcoat is to not overexpose yourself. It's never going to hurt the gelcoat, but it can hurt you (I assume). The trick to using it on paint is - DON'T.
Acetone removes the wax, so that the vinyl will stick. Re-apply a coat of wax when you are done.
