Volvo 5.7Gi fuel problems..
Zoot
I have a 1996 Regal 292 with twin Volvo 5.7Gi engines. Im have a lean fuel problem with one of them. I have replaced both the high and low fuel pumps, cleaned the fuel bowl res, changed filters, changed injectors, rebuilt fuel press regulator.. Its a TBI system. I can see a visual diff between the 2 engines fuel spray patterns. I have learned that volvo uses #74 injectors on these motors and cannot figure out why so much fuel. Its really odd, when the engine is at idle it injects more fuel into one side than the other, but when you rev it up it injects more fuel into the other side.. I have reversed the injector wire caps and it just reverses the spray patters.. Im so confused. It has shrader valves but I cant seem to get a good reading from it.
I would swap the computer between engines. My TBI car experience I have always seen balanced but I have not looked as close as you. You can use an adjustable timing light to view the pattern. Someone one one of the car/truck forums had problems with the injector drivers within the computer but I don't remember the details.
I looked up a 1993 GM ECM, there are no inputs to the ECM that would be left vs right side. The outputs to the TBI come from different drivers A/B within the ECM. You would need 2 O2 sensors one one each exhaust to isolate the TBI's, I think that you only have one. I am voting on your ECM computer. There are places that rebuild car ECM's don't know about marine.
I thought about swapping the ECM's or the throttle bodies, I was just hoping for someone to know a lot about TBI systems. I did use a adjustable timming light to see the fuel patterns.. Its really odd the way its injecting. I thought was maybe one of the sensors were giving a odd signal. Its hard to find a really good Volvo Mech thats know what their doing. I've been on some car forums and they all say the same thing, Its Marine its different.. LOL
Thanks for the help. I will be working on it again this weekend, by the time Im done I will be a Cert Volvo Mech myself..
