as long as you put a good coat of marine grease on the shafts, there is no reason for the props to be hard to some off. growth is not going to prevent them from coming off the shaft, corrosion will if someone forgot to grease the shaft
The critical thing with outdrives are the zincs... you need to check them regularly (once a month).
water is cooler in SF and fresh/brackish in some area so growth will not be a big issue. In So Fl with monthly diver cleaning, you can extend your bottom paint to 2 or 3 years on inboards, although sterndrives will have to come out at least once a year to drain the oil and check belows, etc...
