Volvo always has the sea water pump mounted on the engine. They never put it in the I/O unit like Merc and OMC has done. Get a service manual so you can properly re-install the I/O. When you put it back on, replace the bellows and make sure the u-joints are OK. It'll save you that trouble later.
It should be brass in color. I think it will be in the port side down low. Just follow the water hose from the transom and you will see it go to the brass pump. From there it leaves the water pump and I think it goes to a recirc pump on the block. If you have to take the whole pump apart to put a new impeller in be sure to take note how to reinstall it. It is easily installed the entire pump upside down. If it is installed upside down the new impeller will burn up after a few minutes. For it to operate properly the water remains in the pump for about 3/4 of the turn. The water actually keeps the impeller from over heating. If the pump is reinstalled upside down the water is only in th epump for 1/4 of the turn and the new impeller will over heat.
You will NOT need a manual for this repair. It should take 15 minutes tops. You will not need to go anywhere near the bellows. I had a 1974 Glastron CV 18 with a Volve I/O with a 351 Ford block. It should be the same set up.
