that's what i meant... so it does engage but the drive floats up. by mechanical i meant electric tilt, with along screw mechanism. not hydraulic.
it's indeed your retaining pawl which is supposed to engage and lock the drive down whn you shift in reverse.
first clean it up, maek sure there are no debris, barnacles, etc... also make sure the springs are in place.
it's been a while since i had one but from what i remember there is a rod that goes thru the the drive from the shift linkage. Make sure that's free and in place.
since it happened after you tilted it up, maybe some debris go in there. also, I think there is a rod going to the tilt system to disengage the pawl when you tilt up. if you didn't tilt ALL TEH WAY DOWN, that rid may still be pushing teh pawl out.
also, try turning the drive.... on my old 280, it would sometimes float up when fully turned but not straight.
get the volvo manual, it's a must have...
you can replace the retaining pawl in water...tie the drive up with a line and use snorleking gear... i did that one since i didn't want to haul out. but do it in summer when it's warm or with a wet suit... took ke about an hour and at the end i coudlnt' feel my fingers
