volvo Water Filter
ernesto1840
Need help with my Volvo aq130/270, I rebuilt my 16' stern drive and with the weather not very good to take the boat out, I try to clean the water filter and the manual said not to use any tools but I have no idea when the last time it was clean! it is a 1977 but it's not running hot! but I do what to take care of it, I need any one that can tell me how the best way to remove it?
It is on the right front looking at the eng, it has two thumb nut on top!
Had it out today and it not running hot.
I'm not familiar with your engine, but are you just referring to a raw water sea strainer? ( Similar to the ones on the left side of the page?: http://www.boatfix.com/catalog/656.pdf )
If so, just close the seacock , loosen the wingnuts and and swing the threaded retainers to the side and lift the lid off. Then pull the strainer basket out and flush with water if there is any weed/debris in there. Sometimes it can help to use a hand bilge pump to suck out sand/sediment from the bottom of the strainer cylinder . If the cylinder is glass, wipe the inside with a clean cloth or paper towel to restore ability to check it somewhat from the outside and at least see that it is filled with water. After reinstalling basket and lid I usually slowlly open the seacock just long enough to fill the strainer cylinder , then tighten the lid.
Checking the sea strainer frequently is a good excuse to exercise the seacock so it can easily operated when really necessary.
Reverse the procedure, securing the wing-nuts hand tight only ( the no tools reference was for tightening and it shouldn't be so firmly tightened you need pliers to unscrew.) There is only suction there (running), no positive pressure so you just need to seal so it won't draw air with engine running or of course let the lid fall open with engine off and allow water to make the boat into a bird bath.
Finally, remember to reopen the seacock before starting the engine.
OK, Just saw a diagram of an Volvo OEM water(strainer) filter that was mounted on the engine connected to, and just above, the RW pump. It appeared to be a somewhat small version of the same general idea as I described, but instead of Ernesto's 2 thumbscrews retaining the cap , it simply had 2 pronounced ridges at right angles on a screw-on lid. Definietly had a remove-to-inspect strainer basket inside. I couldn't tell what engines it was for as it was apparently a Swedish site. It may be mounted high enough the lid is safely above the outside waterline and may be suppled directly from a sterndrive with no seacock?, not sure in your case.
Make sure the o-ring or gasket for the lid are in good shape, not stretched out, torn or crushed, & lube with silicone or teflon grease when carefully reinstalling or replacing.
OK i am new to this and I was trying to show the picture, it dose not have a basket it is only 2 1/2" h and 6" w I scan get a hold on it, I can't get it open.
How do you know it doesn't have a basket if you can't get it open? That size fits the image I saw in the Volvo diagram of the on-engine strainer. Not recommending it necessarily, but if it were mine I'd likely carefully apply unscrew pressure on the thumbscrews with pliers or crescent wrench. Even if it didn't loosen I bet that would make it talk. :D Sometimes use of constant lighter pressure for longer time works better than brute force, especially if gaskets or o-ring are involved. The threads might use a little waterproof lube before hand re-tighting the fastener, to ease the next inspection.
