VP DP-S U-Joints
TheBobman
Looks like a nagging leak on my boat turned out to be the bellows (not 100% certain of this as yet, but close to it). Now, a real nasty noise when running that sounds like the gimbal bearing, and maybe u-joints as well. My plan is to pull the boat out tonite and start in on it tomorrow myself. A bit of research has shown me that if the u-joints are bad, I have to replace the entire shaft assembly. My question, for anyone that has done this, is can I just remove the drive, take off the shift mechanism, and then remove the torx bolt holding the shaft, or do I have to totally disassemble the pinion carrier? Seems like if I take out the torx, the shaft should just slip out. Seloc has me disassembling the whole carrier assembly.
