Wake Jumping Is Such Fun!
Can't wait to hear someone chime in that "you're responsible for your wake".
First thought I had was, he got what he deserved but then I came to the conclusion he's lucky to be alive.
I pulled a young lady from the water after the pilot of a boat recklessly flipped the boat she was in. She lost her leg.
The incident looked similar to the one above.
Edit.
The propeller hit her.
Edit.
Watch how close HIS prop gets to him....he is one lucky dude!!!
Here is a better video with slow motion
http://www.youtube.com/watch?v=1UEETjztLqI&NR=1&feature=fvwp
I think this video will show you he definitely IMO was not a dick, not looking to jump the guys wake (he is actually in the smoothest point of the wake) but was just crossing over to get to the other side.
I think the major problem her was the POS boat he had, or he trimmed it up to much and had two much air under the boat.
Looks to me like he actually lost control on the first ( stbd ) wake, where the boat got "out of line". The event could have been avoided at that point ( perhaps ). When he reached the second wake ( port ) the boat was still carrying an odd attitude, and then reacted badly as it hit this wake...
Imho, this was avoidable, in several ways, but it is a good thing he had both the kill switch lanyard and a PFD in action.
"I think the major problem her was the POS boat he had, or he trimmed it up to much and had two much air under the boat.
I think the major problem was he was under the delusion he was in a deep vee offshore boat. Designed to cut through the waves not skip over them.
It sure wasn't the boats fault if he didn't know it's limitations. Or had the trim to high.
this thread should be named... Stupid people are so much fun!
i believe the story goes that he rented a 'chase boat' to film his driving prowess. there's a much longer version around with several passes. while this was the worst, some of the other passes were right near the edge. he pretty much asked for what he got or at least did little to help himself.
the boat barely looked phased. future ad?
edit: link to longer video
A Triton is definitely NOT a POS boat. One of the best in fact. POS driver is what it is.
One very important thing to remember, do not let off of the throttle! You must re-enter at the same prop speed or slightly better. If not the boat will immediately launch to the right when it comes in contact with the water ( been there and done that). In the slow motion link at approx. 2:02 watch the prop. It is a panic reaction and hard not to do, that said one should never put one's self in that position. Wear PFD and kill switch!!
In looking at the video it seems as tho the boat is unstable during some of the high speed passes.
I'm not knocking the mfg..
I was not knocking the manufacture either, although calling the boat a POS certainly says different. If you look closely, you can see the motor is trimmed up and thus creating a situation where the hull is barely touching the water. Now, if the motor is the rated size for that boat, then that's a problem, no?
When I was young and dumb and had the desire for speed and excitement (or as I call it today, being a dick). I had a 18’ Hydrostream with a 225 hp Mercury motor and a ‘jack plate”. The boat easily did 80 mph and the little ripple shown in the video would have no affect on this boat at that speed. Would I be air born, no doubt, did that hundreds of times. I guess that boat was more aerodynamic and or a better hull for high speeds.
I think in the case of this video, the boat was not the kind of boat that should be traveling at the speed it was traveling, and that was IMO, the major contributing factor to the crash.
I would love to know if the boat was equipped with the rated HP motor, or was it overpowered. My guess is it was overpowered.
I happened to watch the second version first and then looked at the one in the original post...what got me was once the guy was out of the water, no oine seems to concerned or in a hurry to go get the guy looked at at a hospital.
Dan
