Wake Zone damage story..
Prospective
I guess if you live long enough everything will happen.
My wife an I were at the fuel dock on Saturday grabbing some diesel in prep for a night away without the kids. Our fuel dock is on a tidal river at the top of Narragansett Bay. In front of the fuel dock are dozens of moored boats and the whole area is a no-wake zone for nearly a mile in any direction. There is a marked channel thru the mooring field.
Well we were preparing to leave and as I glanced around I saw a 36ft Cruisers circling near the marina just to the north of us about 500 yards. I wrongly assumed that they were docking at their marina. I asked the dock attendent and my wife to cast off the lines and the attendent pushed my bow out so I could pull away. As I got about 45 degrees to the dock I looked up to see the 36' boat hauling thru the mooring field, not in the channel, maybe 50 yards off the fuel dock at what I'll guess was about 10knts. What I don't have to guess at was the size of her wake which was big and heading at me. I hollered for them to slow down to which they responded with a puzzled look but then backed off the throttle.
But it was too late, the wake shoved me back toward the dock and forced the corner of my swim platform under the dock. Not realizing or being able to see this I was giving it some throttle to pull away from the dock. Apparently as the swim platform pulled out, it put about a 3" scrape in the top and side of the platform down to the fiberglass mat.
I thought we had gotten off without harm until my wife told me what happened. I did catch up with them in the channel and yelled over to let them know what happened. Turns out I knew them a little. They began to argue with me about it but once they realized they knew me AND that I mentioned I had several wittnesses, they relented.
In the end, they emailed us and apologized, offering to pay for any damages. I think I can fix it myself with a little gelcoat but just goes to show those no wake zones are for a reason. Based on how they drove out of the channel, being on the wrong side of every mark until I showed them the way, they're in need of a basic coast guard class. Perhaps I'll suggest that to them next time I see them....
glad damage was minimal and easily repaired.
when at a dock with wooden pilings, i never leave the dock bow first as no matter what you do it will push the stern close to or into the dock. On most boats, the stern and the swim platform is the most vulnerable part of the boat whereas the rub rail at the bow gives a lot more protection. i always pivot the stern out, bow agaisnt a wooden piling then when at a 45 deg angle i back out.
unfortunately, most fuel dock attendants always try to push your bow out first unless to tell them to back off...
Actually it was a floating dock. And I'm going to have to take a closer look as how exactly it caught the dock. If I had to deal with wind blowing me onto the dock I would have backed out. When it's calm like it was the attendant can often just push the boat off a couple of feet and then I can just swing away gently. Of course thats when I got the wake.
+1
Filled up Saturday, first thing the attendant did was to shove the bow off just as I was shifting the inside engine into reverse... Change of plans!
I dunno, I have always left bow out first without incident. I just toggle the thruster over and away I go......no biggy
When it's calm, if the dock hand pushes the boat off the dock a couple of feet, it's just as easy to take a shallow turn away. I've done it many times. Of course it won't work if wind or tide are holding you on. Or if you have a boat too big to push off. Then you would need to back off perhaps even using a spring line and a fender at the bow. My real mistake was not looking around immediatly before I had them shove me off. I looked just before I hopped back on the boat and saw them about 500 yards away. I assumed they were docking, not leaving. Had I seen them screaming thru I wouldn't have left the dock.
No worry about swim platform damage for me as the outboards protrude further than the platform! Therefore, I too usually leave a dock stern-first.
Prospective-
Did you ever fuel up over at Brewer Sakonnet? Now thats a pain in the stern.
Dan
When the attendant pushes the bow off, I add a little power to the outboard engine. This brings the stern out and you can back or go forward depending on conditions.
A agree. Having a catamaran, my bow is closer to the dock than a mono-hull when leaving at an angle (cats are a rectangle instead of a triangle). So a push on the bow never hurts.
Been my opinion also, have owned multiple sized boats and never had an issue with a dock hand sending my bow out. It's been appreciated so far.
