Walking the stern sideways
AustinPaul
Hey all,
All this talk of docking reminded me that I've been meaning to ask for some secrets that some of you have learned.
In the absence of spring lines, or any lines for that matter, pilings, or any pivot point--- what are some techniques you use for getting the stern (or whole boat) to move sideways. We're talking about twin inboards. I seem to recall using propwash against the rudder(s) to get the stern moving to the side with minimal forward or backward motion.
Paul
steering hard over agaisnt the dock, put dockside engine in reverse, offside engine in forward to pivot the stern off the dock or a piling neat the bow. Pivot point will be just aft of the bow (about 10' aft on my boat). If you are pivoting off a wook piling, you dont' need fenders, the rub rail will do it's job. If i'm on a dock, i put a pair of 18" balls (12" balls will work on yours) to cushion.
once at a 30 to 45 deg angle, I put the second engine in reverse and back out.
that's the only way to get an inboard off a dock when pinned by the wind.
visualize the effect of prop wash on the rudder. it's easy to understand. the flow of water hits the side of the rudder and will push the stern.
propwash can also be used to back a twin inboard on jsut one engine. Put the wheel hard over toward the dead engine. Put good engine in reverse, boat will start reversing but pulling towards the dead engine. momentarily bump the engine in forward, without killing all the momentum. Prop wash will help kick the stern back in line. go back in reverse. repeat.
works great on my boat... not a straight line but it helps.
Thanks Pascal. Yes, I've used those. I was thinking that there was a little magic trick that worked when there isn't anything against which to pivot.
Sounds like the Axius, pods, etc, use the pretty slick computational adjustments to have one pod turned one direction, one in the other direction, one in FW one in reverse, to net a sideways motion. I wondered if there was a version of that, albeit much less effective and pronounced, using rudder and prop wash.
I guess stepping the boat sideways with alternating forward/astern, astern/forward would be another option. Like a sawing motion.
Paul
It seems to depend on prop size and rudder size but if you have big rudders like a trawler or quite small props some boats will walk sideways. Large keels or deep Vees probably interfere. Rudders opposite engines is the idea but on many planning boats the prop wash will over power the rudders and the boat will turn instead of moving sideways; some in and out of gear work helps on some boats. It is really slick to watch when it works.
Most boats will move the stern a bit sideways away from that side when one engine is shifted into reverse while the other is stopped. The bigger the prop the more the movement. "Astern away" is how I remember it. I get a couple of feet with one shift.
That's the 'trick' I was thinking of Bruce. I'll have to try that.
I was just looking at Boating Mag and they were talking about "force vectors" with pods, Axius, etc. To move sideways to starboard, the SB engine swings to SB and pulls, while the Port drive swings to Port and pushes, causing the entire boat to move sideways.
So I'll try to do the same thing (crab sideways to SB)--but with rudders to Port, port engine neutral (with maybe a forward bump?), and bump the SB engine in and out of reverse.
Paul
To get into a tight spot tieing up Stbd side to on a wall with boats ahead and behind:
Stop boat 10 or so feet off the wall.
engines in neutral at idle
Full port rudder
stbd engine reverse
bump port engine in and out of forward to keep perallel to wall.
After three tries throw extra long lines to the boat owners ahead and behind you
who will GLADLY haul you in rather than see you attempt this one more time.
Full port rudder
stbd engine reverse
:-) It would defintely look alick to do that successfully.
Thanks!
Paul
This works for me in my 47' Harbor Master houseboat: Rudders admidships, Shifters back and forth with one engine ahead, oposite astern and idle speed. Of course, if there is appreciable wind on either side, forget about it.
Every boat has been different and none of them have walked directly sideways, more like an angle so start your maneuver a distance behind where you want to end up.
Think of it like this. Turn your rudder all the way to port. If you put your engines in forward gear, think about what would happen. As your prop washes over the rudder it is directed to port, pushing the stern towards the starboard side (and accomplishing a turn). But, we don't want to turn. But, go ahead and leave the rudders hard over to port. Now think about what you would do with your engines to keep from turning to port (even though the rudders are hard over). If you wanted to counteract the port rudders you would go forward gear on the port engine and reverse gear on the starboard. So, now you essentially counteract the tendency to turn left by reversing the starboard engine. The reversed starboard engine pushes the propwash away from the starboard rudder, but the port engine is still pushing its propwash against the port rudder. The tendency to turn is now neutralized, but a portion of the propwash of the port engine is still being vectored away from the boat, now pushing the boat to starboard.
Draw it out and you will see how it works. In practice it can move you sideways without changing the direction the bow is pointed. You do tend to need a little forward velocity in practice though. On the boats I have owned you don't move exactly sideways. Now...if you have a little current on your nose, the effect IS to move directly sideways.
Ghost has it right except I can walk most boats directly sideways, by adjusting the forward and reverse engine speed.
I explain it this way, the rudders will push the stern sideways if at least one engine is in forward and they are turned. The engines push the bow to one side or the other if only one engine is in forward. By combining the forces you can almost make a boat "walk and talk".
Jeez! I'm so confused I don't know if I can even drive my boat anymore.
Rick
