wanted raychart 611 est
fotwins94
I am looking for an old raychart 611 est if anyone has one laying around for sale please contact me
fotwins94- I'm curious as to why you are seeking this control unit? Obviously you either are starting a marine electronics museum or have a V850 which is still a quality color F/F machine if you can find a very very shaded spot for daytime viewing or just use at night. You cannot read this V850 display at all in sunlight. The 610/611 EST was a more or less state-of-the-art rec boat color chartplotter controller for the V850 when I bought one new in 1995 & eventually had it updated long ago to 611EST (to read then-newer CF95 instead of obsolete CF85) by Raytheon. 5 yrs later it was patheticly primitive compared most of the cheapest chartlotters on the market [*Edit note : Amy at CMAP corrected below my previous remarks re: CF95 chart cards. CF95 are currently available & updatable.] That's a 12-13 yr old piece of antique electronics now. The functionability & charting of the 611EST is really awful compared to anything available today. If you are determined to do this to yourself, I will look into removing the one that has sat unused on my dash for many many years while the decent chartplotters onboard get all the use. Sorry to be so negative but trying to save both of us a bit of effort if you aren't aware of this unit's serious shortcomings. Let me know if you are still interested/ determined & I will help .:D
thats alright I already replaced it with a new garmin but I want to keep it as a backup. thanks for the input...
And if you do have one I am interested thanks again for the reply...the blue chart data of the new garmin is incredible compared to the old 611est but like I said removing the integrated raychart system will leave nothing short of an eye sore and a backup unit doesnt hurt...and my 611est used cmap nt cards not the older c-85...
I'm facing the same temporary problem if I remove the 611EST to send to you. Apparently you had a 611EST that no longer works correctly and want to fill the dash bracket or dash-mount hole with a replacement that still will very likely go unused, yes? Mine is a bracket mount on the top center of my dash in between a bunch of other electronics, but the boat is on the mainland stored for the winter. I do have the control unit only stored next door here on the Island, so if you don't need the bracket and cables I may haul the control unit out and send to you so I can finally have good motivation to remove the bracket as well in the spring.
I won't miss the 611EST or eventually the bracket ( I never had the Raytheon GPS antenna as it was NMEA interfaced originally with a Northstar 941 before ugrading that long ago) , so if that will help I will be glad to send for exact shipping cost only. This may finally give me a good spot to place a custom mount for a B&G NetEngine display I've been meaning to install, once I clean up the dash under the old bracket.
The big caveat is that it has been so long since I actually used the 611EST I can't guarantee it's functionality and there is no way to test that with the boat in storage. I know it turns on because I did test just to see if it would still toggle between Chart & F/F. However, if it doesn't work perfectly on your boat, I will be glad to glad to refund double your money , less all shipping costs. :D What happened to yours that it can no longer fill the hole or bracket? (A H/H w/WAAS and up-to-date charts loaded would make a better/safer backup.)
FWIW, I looked up the original dealer invoice net to me in 1995 of just the 610EST controller unit alone , without the V850 or the later expensive upgrade to 611EST: $1260.00 +tax & installation. !( List $1795). The V850 was net $1615(L $2795.) Amazing what that buys today in comparison, but that was great stuff back then.
P.s., As mentioned , mine was factory upgraded to be a 611EST so that it could use the much smaller CF95 "NT" cards like yours that came out in "98 or '99 I believe. . Should look the same. If you e-mail me your shipping & contact info & I'll gladly work on digging it out for you, but are you sure you don't have a better use for that space on yours as well?
I will take the unit like I said I would like to keep it as a backup..the one that I have doesnt hold my boats position, it is flush mounted to my dash and if removed would be nothing short of an eyesore. So if the equipment is there it may as well function properly...I am not sure I understand you say yours was a 610est factory upgraded to a 611est..I am wondering if the wiring from mine would be the same I am guessing that they should be, anyway I tried to e-mail you but they wont let me ...They say I have to subscribe which I did , I guess it takes a couple of days to get my anchor....
In the meantime my e-mail is fotwins94rb2@gr5taol.com...e-mail me and I will send you all the needed info...thanks again I really appreciate it....once again this web site is the best....
the site wont allow me to give you my e-mail address I will be in touch
It just does that to foil spammers. You only have to replace the original ampersand with "at" and I will get it. I'll try <fotwins94 "at" aol.com> later but have to run now.
Yes, the wirng & case is exactly the same as I understand it, the case even reads 611EST now I believe. I'll get the unit out of storage tomorrow.
"and for a long time now the CMap CF 95 cards have had only way out-of-date, possibly dangerous, chart info on them and are obsolete, thus non-updatable. "
The original NT Library is fully updateable and current, just give us a call!
