Vacuflush head. Tank indicator shows 1/2 full. When flushing, water is shooting out the vent. The holding tank is not clear enough to determine if it is full and the indicator is incorrect. What else would cause this to happen?
Originally posted by 3birds
Thank you. Headed there tomorrow.
Originally posted by wkearney99
Tank indicators are notoriously unreliable. Especially ones that use a float inside the tank, or a hollow column. Ones that use an external sensor tend to work better.
Your tank is full and the filter is now ruined. But before you buy a new one, just cut the old one in half and refill it with charcoal used in fish aquariums.
Originally posted by Vic Willman
Gads, David, doesn't take much to make you laugh, does it? You oughta hear some of the stuff I have to listen to, on the phone - you'd be hysterical... [:-bigeyes][:-bigeyes2][:-bigeyes][:-bigeyes2]
Originally posted by Ernesto
Not sure why everyone assumes you have a filter. You may not have a filter. I don't have one in my installation, for example. I would think if you had a filter it'd be harder for water to "shoot" out the vent wouldn't it? At least I would think that the likeliness of something else giving first, before waste actually makes it through the filter at a speed enough to "shoot out", would be higher.
