Watching an engine installation - a big engine
chriscraft67
I took a short break last weekend from getting my boat ready to put back in the water to watch five guys try to reinstall a partially rebuilt Detroit 8V71 engine in a 50 ft Sunseeker. The Sunseeker was in the water and the 8V71 was supported by a crane. The crew (owner plus four helpers, two of which spoke English) had assembled numerous 4X4s, 8X8s, chains and cables and as I walked up to watch, the engine was positioned just under the aft cabin roof of the boat hanging on the crane's jib arm, about four or five feet above the engine beds. (The Sunseeker has its engines installed right up against the inside of the transom on V-drives.)
I've been boating for a long time but I don't think I have ever appreciated how big those engines are. I was told by the owner that it weighed better than 3,000 lbs. and had been removed because one of the two turbos had failed ($7K or so) and had a rusted through oil pan (no price estimate given, but I'll bet quite a lot).
The problem being hotly discussed when I appeared was that the engine had to be supported while the cable on the crane's jib was shortened. That would enable the crane to lower the engine all the way down without damaging the overhanging cabin roof.
The owner called for more 4X4s and bigger lumber and after a lot of discussion in several languages and many commands such as "gimme that 4X4, quick!" the engine was supported across the deck opening and disconnected. The cable to the crane was shortened to almost zero and on the next try, there was enough room to pick the engine up ever so slightly, remove all the supports and lower it into place on the stringers.
After that, the boat's owner decided to move the boat out of the marina and continue the installation elsewhere. Anything to save money, I guess. He fired up his one connected 8V71 and in a cloud of diesel smoke, motored away. As we disconnected his lines he came back onto the aft deck and asked one of the marina guys to, "Watch me, will ya? I might have some bad fuel!"
I wasted almost two hours watching this circus but it was well worth it, just for the laughs.
Okay....I'll watch....and I"ll definitely know if you've got some bad fuel and if you do I"ll swin right out with a 50 gallon drum of good fuel and exchange it for ya?
we do that all the time even its not hard IF you use the right rigging we have an aluminum gantry and trolly system we can configure like an erector set the real secret is having a brake on the trolly so you can control and stop it as the boat list when you remove port engine and move it ontop of starboard the boat tends to list till we get water barrels filled to reballest
I have had my starboard Cummins out to fix a cracked ring. We used a house beam and a skid of bricks to insert it right in the door and adjusted the chain fall on the bricks to ease it into the engine bed.
Two guys and a crane operator $2200 install and the same to remove.
The repair was less than $550.
Yup.....and I really want to get into boating agian ????????????????????????????
LOL Giolic, you know you do :)))) Thanks for sharing chriscraft67. Gary, they make it look easy. We use 100 ton cranes everyday on our construction sites and I appreciate a good operator. I never ourgrew the love of big toysmachines....Stan
Gary: Why did the ring break? What were the symptoms?
There was no real reason why the ring broke, it happened last year on my delivery home. There was greatly increased blowby and blowing oil into the turbo from the airsep, lots of black smoke and 1400 rpms max. I thought it was the tubo and changed that out with a spare but no dice. That was my single engine 600 mile trip at hull speed.
The shop fixed the ring while I used their facilities to clean injectors, cleaned aftercoolers, turbo and airtubes.
Runs like a champ now. It helps when your local Cummins guy is also a vacation buddy.
Nice setup. But when you unhooked the engine, didn't the beam crash up through the cabin roof with all those bricks at the end of it? LOL
No, It's all about triangles. Also the bricks were just over a ton and the engine weighed about 1500 pounds with the transmission so the beam does not move when the engine is unhooked.
That's why they get the big bucks...
Obviously not the same crew that dropped that big Sunseeker a few months back!
I got to see a really big engine a couple years ago. I was touring Mann's parts warehouse in Copenhagen where they stock the parts for engines you would find in tankers, cargo ships, etc. It was cool to see exhaust valves as tall as me and about 2' in diameter. Then they showed us their "little" test engine, a 4 cylinder baby that was about 30' tall and only put out 10,000 hp. The fuel hoses were huge. We asked if they could start it up while we were there, but they were in the middle changing the injectors to try out a new design. They wouldn't have started it anyway, too loud and too expensive they told us. No doubt!
thats the craziest rigging i have ever seen Rube Goldburg would sure be proud! we just pick the engine out of the hole and roll it to the open rear deck then pick it off that got to be the hardest way to do it but i give you an A for effort
Actually Kevin it is easy this way as you can lower the engine down by tilting the beam with the chain fall on the bricks a quarter inch at a time. No need to set up a hoist inside and when the engine is hanging we just pulled the boat forward in the slip and the crane swung it away. And yes, Rube would be proud.
For that kind of bucks I'd think it would be cheaper to fix the engine in place.
That's a creative rig to do engine removal and installation. I watched an installation at the local boatyard once. I don't have pictures. They put the boat in the lifting basin and had the crane use it's boom in the down position. The crane lifted the engine and "raised" the height of the boom (i.e. the boom telescoped out/in). These guys must have done it many times before as they didn't have to reposition the crane but once for each engine. They did use the boat lift to make some adjustments.
Did the crane operator supply the beam, the pallet of bricks, and the chain fall?
its way cheaper to set the engine in back then reach out with a towmotor and pick it off like 4 grand cheaper
No, the mechanic does a lot of engine remove/installs and has the beam and pallet of bricks stored on site.
wow - I had my big block removed once while the harley floated....scary to watch but it worked out fine. The boat was listing so much that I took 5 large coolers, placed them on the empty engine room side and filled them with water... and drove it home on one motor. Three weeks later - we installed again. Not the way I'd do it every time.
