Water in Fuel Problem
gardea23
I have had a hard time starting for a couple of weeks and then I went out and the engine just died during acceleration. She won't restart now. I cleaned all contacts + groundings and replaced the starter, solenoids, and circuit breaker to make sure the ignition system was up to par. The engine still wouldn't start...I then changed the fuel filter/water seperater and it seems that there is water in the fuel. What do I need to do to get back on the water again? It's been almost a month since I've been able to use it. Thanks for your help!
The engine is a 1995 7.4 Mercruiser if it matters......I heard that I might have to empty the tank and/or drain the carb....damn ethanol in gas!
Are you saying you had all water in that filter? If so you would have to get the fuel/water out of the tank completely. If you only had some water and mostly gas I would replace the filter and run it. Check it after a half hour or so and see if you have more water.If you do, dump it out and proceed again. If you do this a few times you should get most of the water out without major pain. When most of the water is out replace the filter again. When working properly the water separating filter will remove all water b/4 it gets to the carb,when the filter becomes overburdened (as in not being replaced regularly) it will let water through. I will get beat up for saying this, but I would also add a bottle of ISOPROPYL alcohol after most of the water is out to the gas to remove any remaining droplets. I have always used one bottle of this in the fall and it never hurt any parts of my fuel system. I had more trouble when I didn't and ended up with corroded fuel pumps and carburetors. Just my .02. Good luck Tom
I would also add a 10 Micron RACOR, which seems to be the most effective against ethanol phase seperation. Runa and check - until you are sure you are through the phase seperation, I would change the filter every 10 hours or so.
I would also bite the bullet and have the tank drained. Do you have an Aluminum or Poly tank?
Personally, I would remove the troubled fuel and then start the cleanup. Part of the problem is that once you get phase separation the remaining gasoline has its octane reduced by about 3 points. This can create other engine problems, like knock. With 12 year old engines I wouldn't push it.
If you haven't been running ethanol-containing gasoline for long then you may also find that the "new gas" is a more aggressive solvent, and can dissolve old gum and varnish deposits in your tanks and filters. If there is enough gum and varnish and you get phase separation, then you may find the famous "brown gel" that occurs when the dissolved sludge mixers in with the alcohol - water mix that separates.
Get the old stuff out, change the filters, put in a modest amount of fresh gas, and get on with it. The problem with isopropyl alcohol is you can't easily get the water-free stuff, which is what you need to really dry the system out - the 90% drugstore stuff is 10% water. If you can (that's 100% isopropyl alcohol) then it's okay to add up to 1.5% by volume for modest amounts of fuel - say 20 gallons. You might try the Startron product from Starbrite at 1 ounce per 8 gallons of gasoline. It has gotten a fairly positive response helping folks recover from the very problem you've encountered. Be prepared to change the filters again soon - after a few hours of running.
I meant to add, on those engines you probably have two filters - a primary and a secondary. Change both filters every time.
What about making a primer bulb pump setup like this to get the water out of the bottom of the tank? Take a look at the link that I found:
http://continuouswave.com/ubb/Forum3/HTML/012877.html
The links in the posting contain photos. Access to my tank is different than the one picture though. It is aluminum though. I have the sending unit and gas inlet tube under my access panel. What do you guys think? Ever try something like this?
