I have a 1991 Carver 33 aft cabin twin 454 330HP Volvos. Is there a easy fix for the deck plate on a Carver that keep letting water into the pipe other than replacing the deck plate. The plate is a Perko PKO1270DPGCHR chrome plate & it seems to be deteriating at the inner edges. I haver replaced the rubber O rings several times but keep getting water into the gas. I have tried different O rings with no effect. One side is fine the other side gets the leaks. Any other ideas ?
FYI - the area where the gas hose connects to the deck plate is almost impossible to get to without taking apart several cabinet side panels.
