Water ingestion
MarcJ
I friend of mine with a 1995 Carver 37 and 7.4 mercruisers just discovered that the exhaust flappers are gone and he is concerned about water getting into the engines. I was with him last weekend and the engines run fine. Is it possible to check if the water got into the cylinders?
Marc
Pull the plugs and inspect them. He needs to get the flappers replaced. Medrc sells a resonator kit to install in the exhaust hose that should work for your friend.
Measure the distance between the top of the risers to the water line. Minimum 13 1/2".
The resonator is just a plastic insert in the rubber exhaust hose positioned a specific distance from the riser.
Thanks for the comments. Would a compression test tell if any water damage has been done already?
You could do it but probably won't tell you much. Look at plugs over time might have helped. Remove the risers and look at ex manifolds for rust in the bottom. If you're really concerned, you can remove the ex manifolds and see the Ex valves/stems.
My friend measured the distance between the water line and the top of the risers. According to him it's greater that 15". Would that mean he is OK?
That greatly reduces the backflow of water up the exhaust. You didn't say if you had IB's but if you do and you have a waterlift type muffler then I would say you're safe.
Charlie,
Thank you for your comments. Just for safety he had the oil analysis done and water was found in the oil. Is there a possibility of permanent damage on the mercruisers.
Marc
'...water in the oil' doesn't tell you anything. Starting and stopping the engine over time 'to make sure things stay loose and lubricated' WITHOUT warming all the way to evaporate off water vapor and any condensation in the engine will put water in the oil.
You could inspect the insides of the cylinders, particularly the center two if a center exhaust like MerCruiser, and see if they are unduly "clean" which is a sign of water entering from the exhaust.
