Water intrusion
Ehoyles
I recently delivered a 1979, 43 Hat (454 gas) and during the 5 days the bilge accumulated 1 inch of water into the center compartment (there are no bilge pump in this compartment and no weep holes to drain into, or from). Since the compartment has no obvious places to leak, I watched for 5 minutes and observed drops of water coming from the starboard stringer through the fiberglass 12 inches above the hull bottom, at the rate of one drop every 5 seconds. Looking further I saw 4 other locations with the same rate of flow approximately the same distance from the hull. When the boat was surveyed there was the usual blistering on the bottom, which the surveyor pronounced as not serious and no obvious delaminating. My question is; can this water be coming from delamination and if so should the surveyor be expected to have found it?
