I have a 2000 Glastron 249 5.0L and have just changed the Raw Water Pump Impeller. After looking at the printout of the parts in that pump, I see the sealing ring and noticed that I didn't see that ring on the shaft of my pump. What I have is a metal washer incased in rubber and looks to be pressed into the backplate of my pump around the shaft. I figure that is the shaft seal. Is that an OEM seal from the manufacturer that has been replaced with an all rubber seal, or is there supposed to be another seal between the impeller and the seal that I described? I have run the motor after replaceing the impeller and the pump does not leak. Thanks
