Grand Larsony
- Jul 29, 2005
- 18485
- 155
Am hoping to save some minor $$ by winterizing my water systems myself this year (1989 Sea Ray 30' Sundancer). Have never done it in the past and have some basic questions.
Planning to do this in my slip before the boat guy hauls it out...
1. Air Conditioner: Can I simply remove the intake hose from the thru-hull (close the sea cock first) and stick it into a bucket of AF, letting the AC run until pink comes out the discharge? Reconnect hose afterwards but leave sea cock closed.
2. Hot and cold water: Run faucets until all tank water is gone, then add AF to fresh water tank. Run all faucets until pink comes out. Leave them in open position, turn off water pump at dash switch.
3. Head (Vacuflush): Get it pumped out, adding clean water and re-pumping-out a few times. Fill bowl 4-5x with AF, flushing each time. Pour some in the pump-out fitting for good measure.
Is this right?
How many gallons of AF will I need for each system and in total?
Thanks for any help !!!
Is this right?
