Wave Runner Vs. 330
airbus
As graceful as I try to appear when I'm out in our boat to give the impression that I know what I'm doing, I become a real klutz when our WaveRunner come into the picture.
My 14 yr old daughter will follow us to our normal anchor spot, then ride until she's worn out.
Now she comes back to the boat, and that's where things go down hill. She'll pull up to the swim platform, hop off, and I'm left with it.
Now what do I do. I've tried to tie it to the side with a couple of fenders, but no luck. It seems to find a way to the gel coat every time.
Any techniques on how to handle this?
Seems to be no graceful way.
If you are anchoring off the bow try to tie it off the stern and pay out enough line to keep it away from the boat. If you want it off the side put the fenders on the waverunner instead of your boat. Adjust lines accordingly.
If you are on the hook and not rafted up, tie it to the starboard stern cleat. Use a couple of "D" links. They are quick and easy. The PWC will swing with the boat. Another option in the same vein may be to have a line on the front eye of the PWC and stuffed in the locker in the front of the PWC. Have a "D" link or backsplice an eye in the end not attached to the the PWC tow eye. Attach a line to the starboard stern cleat with either a "D" link or an eye (which ever is not used on the PWC) at the far end. When your daughter gets finished riding, all she has to do is get the line out of the PWC locker and clip it to the line on the 330. WADR, at 14 she should be doing this herself or not have the privilege of riding at all.
i agree, tie it with 25' of line and let it float behind the boat...
in a protected spot, with no wake, you can get away with tying it alongside using 2 fenders but i prefer to let the damn thing float behind.
I use a long line, I tie a big loop with a bowline through the bow eye of the SeaDoo so it won't slip. When it's time to go out on the SeaDoo I don't have to get to the bow eye to untie it. For the most part it just floats 10-15' behind the boat--actually for the most part someone is on it and it is going 40mph :)
If you want to get fancy with it, install a mooring whip on your swimplatform. :-)
I agree- when we had ours last summer before selling her, we would tie her off a stern cleat and let her float behind us. This worked very well if we only had a bow anchor out. However, if we had a stern anchor on land as well as a bow anchor down so that the boat would stay oriented to the beach, that method doesn't work so well. In that situation we typically would tie a shorter line off ster to bow of the jetski. then I'd tie another line to the back of the jetski and on that attach a 5lb mushroom anchor. I'd push the jetski off the swim platform and toss the mushroom anchor out as far as I could that generally would keep the jetski in one spot for at least a few hours with maybe adjustment needed a time or two throughout the day.
Thanks for all the replies.
I do need her to get better trained.
Airbus, where are you on Lake Norman?
