- Mar 2, 2000
- 36
- 6,694
Cruising South this year we've been delt our share of B.O.A.T.. No big deal if you like boating and it doesn't cream your budget.
But the lucky part of this was that a water pump went while we were traversing the ICW. Once in a while I poke around in the bilge while we are under way and in doing so the other day the raw water pump had let go and was spilling water out all over the place. I caught it before the bilge pumps would have but it was still kind of deep down there. Fortunately I was able to shut down the engine and close the seacock. Then we made our way to a marina.
That seacock happens to be located out board of the prop shaft in tight quarters. Reaching over it I got buzzed a couple of times by the shaft coupling. The rub was just below the arm pit while I had no vertical clearance.
It wasn't spinning fast but even though that engine was shut down the shaft was spinning a bit.
Bad luck or good luck? I guess it depends if your glass is half full or half empty.
So here we are waiting on a pump. At least it came out easy.
