"Weaver Lever" dnghy engine mount
I have an 8.5 Zodiac in a Weaver davit. The engine lays in the cockpit during travels and I am presentlty considering installing a fixed mount for the engine on the cockpit bulkhead. Yet, mounting and removing the engine from the dinghy is becoming a pain. Anyone know of the good/bad/ugly about the Weaver Lever engine mount? it looks like it would put a lot of tourque on the transome when the boat is standing on edge. And, yes it is pricey, but it is a lot less than losing the engine over the side.
Starry Night had one, shoot him an email or PM
If your not in a hurry keep watching ebay for one. I had one and sold it to a friend for a hundred and a half.
I did not have stress on transom, had a small standoff that also connected a larger rail that connected to the swim platform which also connects to the lever cleaver. Be damn careful of the fingers when using one. It will hold up to a 70 pound outboard, I also used block and tackle to raise and lower the tender, you may also find that helpful as well.
I have one and it works great. I did cut the transom down to compensate for the added height the Weaver Leaver adds to the motor.
I used one for a couple of years worked great.
Use the support leg for rough water travel.
WATCH OUT for your fingers, think Weaver Cleaver.
yes, I use the support, it's a must IMHO, holds it very steady and takes most of the pressure off the boat.
Like navman, I had one and ebayed it for about the same $$. Never mounted it but it looked very neat-quite heavy though.
I think if you were selling one it would be, not sure about wanting to buy one.
You have an anchor so I guess if someone has one they can PM you.
Originally posted by Snow Alternative
Is it against protocols to ask if anyone has a Weaver Lever they want to get rid of?
Absolutely not, in fact there is a "buy/sell" forum on this site. Just go there and post your request. Good luck!
