Weight Distribution Hitch
purl
Wondering if they make a weight distribution hitch for boat trailers.I see some hitches for sale but it seems like the connection point on trailer for the bars should be where the trailer starts to "Y" out.Most other trailers ie camper etc. the "Y" or A frame starts fairly close to the coupler where a boat trailer has a much longer straight tongue before splitting off.Any info would be appreciated.
Maybe I'm missing something but the weight distribution hitch has nothing to do with the type of trailer. It has only to do with the tow vehicle and the anticipated load and tongue weight regardless if it is a boat trailer, camping trailer or whatever.
I may be wrong but that's how I understand it.
I remember reading of a company that makes one specifically for surge braked trailers. I can't recall the brand. I'll try and find it later. I ended up swapping out my hitch for a Type V hitch with a load capacity of double my boat and trailer. I also chose a much higher rated ball and mount.
MJK
I've been using a weight distributing hitch from Equalizer for my boat for several years. I started with surge drum brakes and the hitch worked fine. The braking system, however, was junk. I would never use drums again and surge was also sketchy. Now I have electric disc and have been very happy. The Equalizer also continues to please. My Expedition is rated for towing only 5,000 pounds, but, with a WD hitch, 9000 pounds. I like 'em.
Peter
http://equalizerhitch.com/public/SB/PoleTongueTrailers.pdf They work great on pole tongue trailers and with surge brakes.
I had used a standard wd hitch last year on my old setup. You can buy an adapter for the trailer so your hitch y's out as you said, in fact I still have it and would send it to you if you pay the shipping.
I'm not sure my surge brakes worked very well with it though. Hard for me to say for sure because they never worked very well without the wd hitch either.
Pm or email me if you want the tongue adapter.
James
Over the last 2 summers I have driven over 12,000 miles towing a 7500 lb boat with a "Weight Equalizer" hitch. Disc Surge brakes work well with this. There is a "pole tongue" adaptor, which allows it to be used with any square tongue, or you can go to a V frame directly. It made a huge difference in tire wear and ease of trailering.
