Wet cap/rotor.
Shore
Ok so how do we stop this?
I know this is a common problem even though we use the gasket and the correct cap it still manages to somehow get condensation in there.
Mine got it yesterday with a bunch of wet people.When I got home I pulled the hatch and you could see the drip marks on the back of the cover over the distributor.
I'm guessing this cover needs to be about 3" longer
7.4 gen IV
Is the distributor cap vented, so as to decrease the condensation on the inside?
Yes it has a fitting on the outside..the cap and rotor are an hour old Sierra parts.
You may have moisture in your crankcase and it is condensing in the cap. Check your oil for being milky.
Oil is clean.
I took the cap off this morning and it is dry.I did see a couple terminals that looked a little burnt.I have a spare cap/rotor so no big deal.
However, I did notice the gasket was pinched to one side because some tard,that would be me,didn't take the plastic tape off the one side to stick it down.
I'm thinking cold water on hot intake and steam got inside easily.
I was only down a couple cylinders IMO.It would start right up but you could feel a miss.It took an hour to get home and only once did it try to clear out in the handful of times I tried to get her to plane out.
Shore: coat internal dist cap components with dielectric grease (hi temp). I had issues with a wet distributor and it helped a ton. I use it liberally on everything under the cap (any metal-to-metal contacts).
I wasn't aware that was a good idea.I do put it in boots though.
I did find a piece of rust/debris stuck on the leading edge of the pick-up.It was like a little flake of rust.
Probably not related to what you are seeing, but it is very important to keep the dist. vent screens clear & clean to minimize cap-electrode and rotor tip corrosion by allowing maximum ventilation.
Echelin even goes so far as to advise knocking out the vent screen(s) on many GM engines distributors , but never do this on a marine engine.
Have you hosed off the engines while they are warm. Cold water from the Hose may have caused Condensation inside the cap?
We ran the boat to the island and that takes about an hour....a few hours later we left and that is when the miss showed up.It ran perfectly on the way out.
I was having the same problem - always on the 2nd or 3rd leg of the day, never the first. The dielectric grease helped, but I now also leave my engine cover open slightly and really vent the moiture out of the hot engine compartment after my first stop of the day. This has helped to the point where it does not misfire much any more.
Are you sure it's not coming in from the top? Newer MerCs have that long plastic cover held down by the flame arrestor nut. Supposedly makes the engine look cute, doesn't help the flame arrestor at all, but the long tail on it serves as an umbrella for the distributor. If you don't have one, adding one might help.
Back in the day (pre computer anything under the hood) when I was fanatical about power washing my engine compartment. I used an inverted quart rubbermade type container with a few carefully placed slots, over my distributor. It made a water resistant cover for the distributor.
I have the long black merc cover on it..It goes back pretty far but I could see were the saltwater was dripping(left that tell-tale white residue) on the end of it but I could not tell it ever hit the cap..like I said before I think it was cold water dripping on a hot intake and causing steam....that or the piece of trash I found on the pick-up for the rotor.Hard to say which it was but I had just put new plugs/wires/cap/rotor on it.
