wham mic or handheld
tcijoe
i have an upper and lower station. on the lower station i have a WM vhf600 which is wham mic capable. on the flybride i have a standard vhf.
i did this to have two completely redundant systems onboard.
my question is when i cruise with other boats it becomes a real pain to moniter both our cruising channel and 16.
what my thought is would be to put in a wham mic and use it on the flybridge.
then i go and price out a wham mic only to find that i could buy a handheld vhf for the same or less.
what benefits do i have one way or the other???
TC-I am looking at the same issue with a boat I am thinking of purchasing. In your case the advantage of the Wham is that it is transmitting and receiving through a 25 watt radio versus 5 or 6 for a handheld. You can also use the wham as an intercom with the lower station.
glen - you raise a good point about the power. since i would be using it to talk with the boat behind me...i am not sure that is a real concern.
i do like the intercom with the lower station...however if i had a handheld i could put the lower station on ...say 68 and tune the handheld to 68 also.
i really think i am leaning toward a handheld
Get the handheld. You can take it with you in your dinghy then and be safer when you do.
Otherwise, the wham mic is a good idea.
If my current radio, which is 15 yr old, ever bites the dust, I intend to install a black box VHF with a WHAM mic. I can't read those little screens anyway.....so I don't need it.
My current set up is a WAM wireless Uniden mike at the helm up top where I also have a pair of handhelds one I leave on channel 13 or scan mode with 9, 13 & 16 and the other is a multi-band I usually keep it on an FRS channel I use. The WAM mike is on channel 16 with the weather alarm mode set. Regards Bill
tcijoe- Don't your upper & lower station VHF's have "dual watch" or programmable scans with ch.16 priority?
